RTC input
RTC input
2,479 次查看
Leon797
Is it possible to insert LVCMO signal into the RTC input?
4 回复数
2,467 次查看
xiangjun_rong
Hi, Leon,
I  never hear about the "LVCMO" signal, can you tell us the part number you are using? where the "LVCMO" signal is?
XiangJun Rong
2,461 次查看
Leon797
I meant LVCMOS
2,452 次查看
xiangjun_rong
As you can see in the following Fig, the RTCXIN/RTCXOUT pins can only connect to Crystal, it can not connect to clock source which outputs squarewave clock signal directly.
Hope it can help you
XiangJun Rong
2,448 次查看
Leon797
Thank you for your response
