RTC in LPC4337
RTC in LPC4337
703件の閲覧回数
amit1234
RTC in LPC4337 requires 2 secs to be able to write to the RTC registers. Can we speed up this process like to a few miliseconds?
Amit.
560件の閲覧回数
Carlos_Mendoza
Hi Amit,
This should be the expected time, the write operations to RTC registers are buffered and only become effective after the next 1 Hz clock pulse of the RTC. If the CPU attempts another write before the previous write has taken effect inside the RTC, the CPU will stall until the next 1 Hz clock pulse.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
