LPCXpresso: debugging a core of two
593 次查看
lpcware
Content originally posted in LPCWare by dima2611 on Wed Feb 22 09:20:54 MST 2012
when I start debugging with Red Probe+, I'm told that it descovered two targets at the JTAG. Sounds like it is talking about both cores (M4/M0).
How can I say which is which since they have cryptical IDs and nothing more. And then, there is a catch 22: I'm asked only once per session. I cannot see (or I don't know where it is) what I have chosen. I cannot change my mind and switch to another core (I know I have to recompile the project anyway).
/Dima
P.S. with some example projects I get "Error launching debug/xxx.axf
02: Failed on connect: Ep(04). Cannot halt processor.
Emu(1): Conn&Reset. Was: None. DpID:  BA01477. Info: FTV7DHR0A
Is the JTAG stuff really that buggy and unsure?... Or was it the wrong core which I cannot switch back?
579 次查看
lpcware
Content originally posted in LPCWare by dima2611 on Thu Feb 23 03:54:23 MST 2012
It is solved.
Cortex-M4 is "device 1 - Coresight JTAG DP - 0x4ba00477"
To modify the selection, just delete .jtag file in Debug or Release subdirectory. Then, you will be asked again.
The ISP pin (P2.7) may not be floating which was the case.
579 次查看
lpcware
Content originally posted in LPCWare by dima2611 on Wed Feb 22 09:30:56 MST 2012
Here are the two targets to choose from
