LPC8N04 EEPROM endurance
965件の閲覧回数
kenchill
Hello
Are there any specifications for EEPROM or FLASH endurance for the LPC8N04 ?
All the data sheet gives is 10 year min data retention time for the EEPROM it gives no endurance or write times (the same goes for the FLASH).
We have a 32-bit counter that needs to reside in EEPROM which could be incremented once every 10 seconds over a life of 5 years, so some sort of wear-levelling algorithm needs to be used - but this is impossible without more info on the EEPROM.
There are a couple of other EEPROM issues:
(1) There is no info for setting the value in the RWSTATE and WSTATE wait registers, only magic numbers are given - will these values work for all clock speeds and temperatures or do they need to be scaled?
(2) The API won't work with a 500kHz clock - in table 8 of the user-manual it states that 500kHz is ok, but the API sets the CLKDIV to zero if this speed is selected causing a hardware exception - is this a bug in the API? the following is extracted from the 'EEPROM_Init()' function:
/* Set the clock divider */
clockDiv = sourceClock_Hz / FSL_FEATURE_EEPROM_INTERNAL_FREQ;
if ((sourceClock_Hz % FSL_FEATURE_EEPROM_INTERNAL_FREQ) > FSL_FEATURE_EEPROM_INTERNAL_FREQ  / 2U))
clockDiv += 1U;
base->CLKDIV = clockDiv - 1U;
Thanks for any help
Ken...
ラベル(2)
タグ(2)
881件の閲覧回数
Alexis_A
Hello kenchill‌,
I've already reported the issue with the applications team, it looks like the EEPROM_Init should have the following condition:
if (base->CLKDIV < 1)
    base->CLKDIV = 1;
Alexis Andalon
