LPC865 MRT not regular interval
1,041件の閲覧回数
rmaier
Nullify this. There was a spurious interrupt from elsewhere causing an issue. Problem solved.
I am using the MRT to generate a fixed pulse on a GPIO output. However, depending on the command INTVAL the MRT timer has a longer or shorter interval actually being revealed.
The core is running at 60MHz. When the timer is loaded with anything above 15,600 the actual output as measured on a scope on the GPIO output is 246 us longer. When the INTVAL is loaded with anything below 15,000 the output is 7 us shorter than expected. It's a consistent offset 15,600 or 600,000 all is 246 us longer than expected.
Here's the code launching the MRT timer:
void mrt_Launch(uint32_t val)
    val = 60 * (val);
    MRT0->CHANNEL[0].INTVAL = val | MRT_CHANNEL_INTVAL_LOAD(0b1);
    MRT0->CHANNEL[0].STAT turnon MRT_CHANNEL_STAT_INTFLAG_MASK;
    PIN_CLEAR(GPIO_XYZ_PORT, GPIO_XYZ_PIN);
    MRT0->CHANNEL[0].STAT turnon MRT_CHANNEL_STAT_RUN(0b1);
Then the interrupt is handled like so:
void MRT0_IRQHandler()
    if (MRT0->CHANNEL[0].STAT & MRT_CHANNEL_STAT_INTFLAG_MASK)
        PIN_SET(GPIO_XYZ_PORT, GPIO_XYZ_PIN);
        MRT0->CHANNEL[0].STAT turnon MRT_CHANNEL_STAT_RUN(0b0);
So, based on this an input for val over 260 has a 246 us longer interval, and a val of under 250 is 7 us shorter interval.
I didn't see anything directly addressing this in the user manual. Any tips for what I'm doing wrong here?
Robert
4 返答(返信)
1,022件の閲覧回数
rmaier
I've attached an image of the chart of measured vs command MRT timer interval in another test. There is a marked step around 64,000 ticks. It's not 65535, but it's awfully close.
987件の閲覧回数
Miguel04
Hi @rmaier
Can you provide images from the osciloscope please?
I'm looking into your issue.
Best Regards, Miguel.
984件の閲覧回数
rmaier
Hello Miguel,
The problem has been resolved. I discovered a spurious interrupt that was launching another MRT event. Since it was overlapping it wasn't immediately evident on the scope trace. Root cause: User error.
Thanks for your support.
Robert
973件の閲覧回数
Miguel04
Hi @rmaier
I'm glad you were able to solve it.
Please let us know if you have another question.
