LPC1124 HARDFAULT WHILE INITIALISING A PIN AS OUTPUT
884件の閲覧回数
pascalcarreweyn
i'm trying to make a simple led switch on or off with an LPC1124   P3.4
but when i'm initializing, i alway end up int HardFault_handler
I have no idea what is wrong ?
/* Initialize GPIO */
 Chip_GPIO_Init(LPC_GPIO);
 Chip_GPIO_SetPinDIR(LPC_GPIO, 3, 4, true); // WHEN I DO THIS I END UP in HardFault Handler.... why is this ?
The same thing works for the LPC 11U37
If i try the same thing even with the blinky project i have the same error while debugging...
3 返答(返信)
784件の閲覧回数
jeremyzhou
Hi pascal carreweyn
To provide the fastest possible support, I'd highly recommend you to use the demo in the LPC1125's LPCOpen library.
LPCOpen Software for LPC11XX | NXP
TIC
784件の閲覧回数
pascalcarreweyn
Hi Jeremy,
Thanks for the help but i already solved the problem.
It was a hardware problem with the debugging cable which gave me this strange effect...
Pascal
784件の閲覧回数
jeremyzhou
Hi pascal carreweyn,
Thanks for your reply.
Goad to hear the issue had been solved.
If you have any further questions about it, please feel free to contact me.
TIC
