How RAM and Flash actually work?
1,371 次查看
dimitrissideris
I am trying to understand the procedure memory handling in LPC mcus.
I am working with an LPCxpresso 4367.
I wanted to store a buffer in flash I tested this code:
#include "board.h"
#define FLASHA_BASE_ADDR 0x1A000000
static int *fb  = (int *)FLASHA_BASE_ADDR;
int main(void)
    SystemCoreClockUpdate();
    Board_Init();
    int arsize = 10;
    for (int i = 0; i < arsize; i++)
        fb[i] = 0xA;
    while (1) {
        __WFI();
And after adding -print-memory-usage linker option i get this result:
MFlashA512:        7984 B       512 KB      1.52%
RamLoc32:          352 B        32 KB         1.07%
I went through normally without declaring specific address to fb buffer and i tested this code:
#include "board.h"
int main(void)
    Board_Init();
    int arsize = 10;
    int fb[arsize];
        fb[i] = 0xA;
    while (1) {
        __WFI();
MFlashA512:        8044 B       512 KB     1.53%
RamLoc32:          348 B        32 KB       1.06%
Can some explain what is going on?
When i put fb in flash, flash occupied space is less.
When i put fb in ram, ram occupied space is less.
4 回复数
990 次查看
converse
Senior Contributor V
Your  2nd example place fb on the stack, so it is 'allocated ' at run time .
in fact your 1st example doesn't place fb in flash either... suggest you look up the meaning of static in C
990 次查看
dimitrissideris
Did run again the examples without static. Same results
example1:
example2:
As far as example2 is concerned, ok it is allocated on run time. But why flashA has more space occupied?
For example1 the question is if i can store this way a variable or a buffer in Flash memory
990 次查看
Carlos_Mendoza
Hi Dimitris,
In addition to Con Verse information, I think that the following post could also help you understand how data is stored in Flash and RAM:
text, data and bss: Code and Data Size Explained | MCU on Eclipse
Hope it helps!
Carlos Mendoza
Technical Support Engineer
990 次查看
converse
In C "static" defines the scope of a variable - it says nothing about where it is stored. When applied to a variable defined in a module, the variable is only visible within that module. Look up "C storage classes" for more information.
Flash is like ROM - you cannot write to it. So you cannot place a buffer in flash and expect it to work. Flash is for storing stuff that doesn't (or very rarely) changes. Flash can be *programmed* in blocks (sectors, or pages) by using a special algorithm, depending on whose flash is used - in NXP this is achieved by using the IAP calls as described in the User Manual.  For more info, see Flash memory - Wikipedia.
