I am using a TWR-KV46F150M board. I have Knietis SDK v.1.3.0_KV4xF_1.0.0 installed. I would like to use the driver fsl_flexcan Peripheral Driver. I added it to the Components, everything looks filled out. I am not sure where the setup is done. I am assuming the application will have to call some functions.
The problem is when I try to generate the code, I get the following message
ERROR: Not possible to run: Drivers\Kinetis\printConfigs.js. javax.script.ScriptException: sun.org.mozilla.javascript.internal.EcmaError: TypeError: Cannot find function getEditorData in object com.processorexpert.core.service.api.internal.PExInspectorIntegerItemAPI@680703. (<Unknown source>#89) in <Unknown source> at line number 89
Any ideas what I am missing?
已解决! 转到解答。
Hi Robert Heldibridle
What version of IDE do you have? I'm using KDS 3.2 and processor expert 3.0.2 and I don't see this problem.
Also, what OS do you have?
Have a great day
Jorge Alcala
Thanks for getting back to me,
This is from the help...
KSDK 1.3.0 KV4xF Eclipse Update | 1.0.0.b151015 | com.freescale.processorexpert.kinetis-168mhz-kv4xf.sp.feature.group | Freescale Semiconductor, Inc. |
Processor Expert Kinetis SDK Support | 1.2.0.RT7_b1515-0427 | com.freescale.processorexpert.feature.core.kpsdk.feature.group | Freescale Semiconductor, Inc. |
Processor Expert for Kinetis | 3.0.0.RT7_b1515-0427 | com.freescale.processorexpert.kinetis.feature.feature.group | Freescale Semiconductor, Inc. |
Pin Settings | 1.1.0.RT7_b1515-0427 | com.freescale.processorexpert.feature.pinsettings.feature.group | Freescale Semiconductor, Inc. |
Processor Expert Base UI | 1.4.0.RT7_b1515-0427 | com.freescale.processorexpert.feature.core.ui.feature.group | Freescale Semiconductor, Inc. |
Processor Expert Base Wizards | 1.4.0.RT7_b1515-0427 | com.freescale.processorexpert.feature.core.wizards.feature.group | Freescale Semiconductor, Inc. |
Processor Expert Core | 1.4.0.RT7_b1515-0427 | com.freescale.processorexpert.feature.core.feature.group | Freescale Semiconductor, Inc. |
Processor Expert Custom Views | 1.0.0.RT7_b1515-0427 | com.freescale.processorexpert.feature.custom.mcu.feature.group | Freescale Semiconductor, Inc. |
Processor Expert Flexnet License | 1.0.0.RT7_b1515-0427 | com.freescale.processorexpert.feature.license.feature.group | Freescale Semiconductor, Inc. |
I think I have everything.
I'm working in your issue, Did you install the eclipse update for KSDK 1.3.0 KV4xF ? Could you please check the installation details and tell us if you can see KSDK 1.3.0 KV46xF Eclipse Update and processor Expert for kinetis?
I've created the project based on your description and I do not see any problem with code generation.
Jorge Alcala
