“Term”
953件の閲覧回数
shauldorf
Contributor V
What is the reason that “Term” component isn’t supported in KSDK1.2 ?
Shaul
780件の閲覧回数
ZhangJennie
hi Shaul,
as I know, ksdk component doesn;t have exact Term feature.
I suggest you escalate it as a feature request to support@freescale.com
hope this helps!
Zhang Jun
3 返答(返信)
780件の閲覧回数
shauldorf
Contributor V
Hello Jennie,
Thanks’
Using Term component there are methods to manipulate cursor and screen clear that are not used by printf operations.
How screen operation can be implemented using fsl_xxx components?
Shaul
781件の閲覧回数
ZhangJennie
hi Shaul,
hope this helps!
Zhang Jun
779件の閲覧回数
ZhangJennie
Term component is legacy component that generated code doesn't support KSDK low level driver.
Freescale creates a set of KSDK compatible component, start with fsl_xxx or Init_xxx
We can use KSDK with processor expert to print string to console. See this document:
https://community.freescale.com/docs/DOC-104349
can this help you?
Zhang Jun
