hi Shaul,
as I know, ksdk component doesn;t have exact Term feature.
I suggest you escalate it as a feature request to support@freescale.com
hope this helps!
Zhang Jun
Hello Jennie,
Thanks’
Using Term component there are methods to manipulate cursor and screen clear that are not used by printf operations.
How screen operation can be implemented using fsl_xxx components?
Shaul
hi Shaul,
hope this helps!
Zhang Jun
Term component is legacy component that generated code doesn't support KSDK low level driver.
Freescale creates a set of KSDK compatible component, start with fsl_xxx or Init_xxx
We can use KSDK with processor expert to print string to console. See this document:
https://community.freescale.com/docs/DOC-104349
can this help you?
Zhang Jun
