SPI with edma (32byte align problem)
958 次查看
martinmadron
Hello, my program keeps crashing when i try initi my DSPI driver. Worked without edma fine.
Here
dspiResult = DSPI_DRV_EdmaMasterInit(SPI0_IDX, &dspiMasterState, &userConfig, &stcdSrc2CmdDataLast);
    if (dspiResult != kStatus_DSPI_Success)
        PRINTF("\r\nERROR: Can not initialize master EDMA driver \n\r");
Driver says stcdSrc2CmdDataLast has to be 32 byte aligned. I have used gcc atribute to set align, no warnings or errors.
typedef struct EDMASoftwareTcd {
    uint32_t SADDR;
    uint16_t SOFF;
    uint16_t ATTR;
    uint32_t NBYTES;
    uint32_t SLAST;
    uint32_t DADDR;
    uint16_t DOFF;
    uint16_t CITER;
    uint32_t DLAST_SGA;
    uint16_t CSR;
    uint16_t BITER;
} edma_software_tcd_t __attribute__ ((aligned (32)));
Original Attachment has been moved to: customDspi.c.zip
573 次查看
Jorge_Gonzalez
Hello Martin Madron:
Exactly what board or Kinetis part are you using?
In the Kinetis SDK installation there are some ready to test DSPI+DMA driver example projects in the path:
...\KSDK_1.3.0\examples\<board>\driver_examples\dspi\dspi_edma_blocking
...\KSDK_1.3.0\examples\<board>\driver_examples\dspi\dspi_edma_non_blocking
You can start with one of those as reference and then integrate the code to your custom project.
Regards!
Jorge Gonzalez
573 次查看
martinmadron
its frdm-k64. Those examples you have suggested are exactly same as my implementation. Program is using USB cdc and MQX with ksdk. I have read on this forum that it can be caused by USB using DMA. Is it possible?
