SDK 2.0 PWM configuration, ¿bug?
1,123 次查看
anthonyLoren
Hi, I've been working with SDK 2.0 for kinetis MK22FA12..
In the archive fsl_ftm.c it seems to be a bug when configuring PWM (high-true or low true selection).
The result of this:
reg &= ~(FTM_CnSC_MSA_MASK | FTM_CnSC_MSB_MASK | FTM_CnSC_ELSA_MASK | FTM_CnSC_ELSB_MASK);
reg |= (FTM_CnSC_ELSA(chnlParams->level) | FTM_CnSC_ELSB(chnlParams->level));
when level is kFTM_HighTrue (2U)
is always ELSA = ELSB = 0,  i.e. 00
down below, in the same file there is another line that looks better:
reg |= ((uint32_t)chnlParams->level << FTM_CnSC_ELSA_SHIFT) & (FTM_CnSC_ELSA_MASK | FTM_CnSC_ELSB_MASK);
Is this ok or I'm missing something ?
Thanks in advance.
标记 (1)
896 次查看
ivadorazinova
Hi Antonio.
Yes, this was a bug which was already fixed in latest release.
The root cause about code is that, the type for “chnlParams->level”, “ftm_pwm_level_select_t”,  is defined as:
/*! @brief FTM PWM output pulse mode: high-true, low-true or no output */
typedef enum _ftm_pwm_level_select
    kFTM_NoPwmSignal = 0U, /*!< No PWM output on pin */
    kFTM_LowTrue,          /*!< Low true pulses */
    kFTM_HighTrue          /*!< High true pulses */
} ftm_pwm_level_select_t;‍‍‍‍‍‍‍
The value of enum item is also the mask for the two bits field (FTM_CnSC_ELSA_MASK and FTM_CnSC_ELSB_MASK), in previous version you have
Then we fixed it and changed to use the current one, which is corrected now.
            /* Setup the active level */
            reg |= (uint32_t)(chnlParams->level << FTM_CnSC_ELSA_SHIFT);‍‍
So, I recommend you download the latest version KSDK (which is available now) or for quick fix (but not a good way) replace this part of code.
Iva
897 次查看
ivadorazinova
Hi Antonio.
Iva
896 次查看
anthonyLoren
Hello Iva:
after building a new sdk for this configuration: SDK_2.0_MK22FN1M0Axxx12 / SDK 2.0 / KDS / Windows .
It seems to have the same fault code,  like the former one.
Is that the right way to get the newest SDK version ?
