UART on kl25z
已解决
UART on kl25z
跳至解决方案
2,163 次查看
aayushm
Fresh Out Contributor
What is the differnce  between UART0, UART1, UART2 on kl25z ?
What is the operating voltage of RX/TX pin of kl25z ?
1 解答
1,924 次查看
hectorsanchez
Hi Aayush,
As you can see on the datasheet:
And the operating voltage depends on VDD.
Hope this helps,
Hector Sanchez
在原帖中查看解决方案
1 回复
1,924 次查看
hectorsanchez
Hi Aayush,
Hope this helps,
Hector Sanchez
