Pulse not counting properly using LPTMR
1,320件の閲覧回数
shabana
In using LPTMR to count the pulse.
here is the snip shot of the code
void lptmr_pulse_count(uint32 count_val, int pc_src, int psg_src)
  // Reset LPTMR module
  lptmr_clear_registers();
  // For interupt handler
  lptmr_mode = LPT_CNTR_MODE;
  // Enable LPT Interrupt in NVIC
  enable_irq(LPTMR_IRQ_NUM); // LPTMR Vector is 101. IRQ# is 101-16=85
  // Set up the interrupt vector for counter == compare val
  // Set the compare value
  LPTMR0_CMR = count_val;
  // Set up LPTMR to bypass prescaler clock
  LPTMR0_PSR = (LPTMR_PSR_PBYP_MASK | LPTMR_PSR_PCS(psg_src));
  // select pulse counter mode, pulse counter clk src, and interrupt enable.
  LPTMR0_CSR |= LPTMR_CSR_TMS_MASK | LPTMR_CSR_TPS(pc_src) | LPTMR_CSR_TIE_MASK;
  LPTMR0_CSR |= LPTMR_CSR_TEN_MASK;
  lptmr_intrpt = 0;
  return;
count_value = 0xFFFF
clock source is LPO.
in oscilloscope I counted the pulse it is 22 but in CNR register the value is 69.. please see the image for the pulse
993件の閲覧回数
yasuhikokoumoto
Senior Contributor I
Hi Shabana m,
do you mean the glitch filter clock is LPO?
However you disabled (or bypassed) the glitch filer.
I think the error came from the input signal glitch.
Therefore you should better set the glitch filter as the following
because your input signal is 2.27MHz and LPO is 1kHz.
[before]
[after]
LPTMR0_PSR = (LPTMR_PSR_PRESCALE(0x6) | LPTMR_PSR_PCS(psg_src));
// PBYP=0 PCS=psg_src=0b01(?) PRESCALE=0b0110=128cycles(220cycles would be best but not available)
This means that the input low level should keep longer than 128ms and the high level should keep longer than 128ms.
I hope this will help you.
Yasuhiko Koumoto.
2 返答(返信)
994件の閲覧回数
yasuhikokoumoto
Hi Shabana m,
[before]
[after]
Yasuhiko Koumoto.
993件の閲覧回数
shabana
Hi Yasuhiko koumoto,
Thank u sooooo much...Its working... :smileyhappy:
Shabana
