P.E. K70 and LCD Question
1,079 次查看
crezyoz
I am just getting started with PE. Trying to build an LCD driver for a monochrome Electro Luminiescent display. (HYSNC/VSYNC/ 2 wire interface/1bpp)
However, when I go to set the Pixel Clock there is no entry in the Component Inspector.  It is blank. Everything else went ok.
Any advice?
928 次查看
crezyoz
Found it.. sorry for the noise.
929 次查看
crezyoz
928 次查看
squadmcu
Hi Phil! How did you solve this?
928 次查看
crezyoz
After a good deal of trial and error I determined that the type of EL display I am using can not be driven from the K70 in the 1bpp mode. Apparently the K70 can not keep the pixel clock running continuously in that mode only . So I had to use 8bpp mode and only use one bit to drive the display. This had a negative impact on my design because it meant I had to add DDR to the design. The frame buffers grew to 128k and I need 4 of them. I REALLY wish it had worked. I hope they make it very clear in the next set of docs for the LCD interface. It was an expensive week figuring that one out.
