NC pins FRDMK 64F
NC pins FRDMK 64F
1,244件の閲覧回数
juancarlossuare
Hello.
I bought a FRDMK 64F.
I reviewed the headers and find that there are pins called NC (Not conected). I thought that these pins are avalaible for other pins configuration (eg peripeherics) as well as users want. ¿Is it right or wrong?
If these pins are no routed to the MCU, what is your function or utility?
I'm very confused with this and I'm very dissapointed.
ラベル(2)
1,170件の閲覧回数
danielchen
These pins are trully no connection pins.
Some of there pins are used for factory test and if you want the expected behavior from the MCU, these pins shall be floating.
