Mismatch of KL25Z pin numbers between Pinout and User Manual documents
784 次查看
fireflies_at_night
Hi everyone,
I was looking at the FRDM-KL25Z MCU documents for User Manual (Rev 2) and Pinouts (Rev 1.0) and saw an apparent discrepancy between PTE0 and PTE1 assignments on the board?
In the Pinouts, PTE0 is assigned to J2 20 and PTE1 is assigned to J2 18, while in the User Manual Pg14, PTE0 is assigned to J2 18 and PTE1 is assigned to J2 20.
Which one should I follow here?
Thanks!
764 次查看
Miguel04
Hi @fireflies_at_night
The correct pinouts are PTE1 J2-20 and PTE0 J2-18, depending on your KL25Z you will have a printed pinout on the back side of the board. Thanks for reporting the mismatch, I'll report it as soon as possible.
Best regards, Miguel.
765 次查看
Miguel04
