KV4x PWMA-PDB-ADC triggering with Nano Edge placement
katha
is there a possibility to get an example for KV4x according to AN4410.pdf or at least according to AN4675, AN4675.pdf ?
An demo-app like for frdmk64  "ftm_pdb_adc16" would be great.
Many thanks and regards
EdwinHz
We don’t have that specific code example for the MKV4x. However, these modules are initialized used similarly across our Kinetis family of MCUs. So you should be able to port the MK64 “ftm_pdb_adc16” demo app for your specific part number. Also, you can use the code found in sections 4.3 and 4.4 as guide.
Edwin.
