K61 Controller Ethernet Link Establish Problem
703 次查看
mani8421
We are working with KSZ8041NL for our requirement with K61 Controller.
when we are connecting the Ethernet cable to the Jack the two status LED’s simultaneously go ON and OFF continuously as long it is connected. And the link is not established between Host PC.
Can any suggest what could be the problem
标记 (3)
564 次查看
hectorsanchez
Hi Mani,
Looks like you have activity on the port and probably the jacks or the cable is not working as intended, try to change the cable and test the jack on another device.
Hope this helps,
Hector Sanchez
565 次查看
hectorsanchez
Hi Mani,
Hope this helps,
Hector Sanchez
564 次查看
mani8421
Hi Hector,
Thanks for the reply
     Problem is solved by changing the Ethernet Jack....
Thanks and regards,
      MANI
