Hi everybody,
I need some help to speed up my core. Before I start to explain my problem - just two things to know:
- I use Keil ARM with RL-RTX for my board, so there is no Processor Expert and MQX available
- I also use the CMSIS header file
okay, according to CMSIS, i have the C-file "system_MK60N512MD100.c" in which is the function SystemInit()
There are also 3 predefinded configurations to setup the clock.
here the code:
#define CLOCK_SETUP 3/* Predefined clock setups 0 ... Multipurpose Clock Generator (MCG) in FLL Engaged Internal (FEI) mode Core clock/Bus clock derived from an internal clock source 32.768kHz Core clock = 47.97MHz, BusClock = 47.97MHz 1 ... Multipurpose Clock Generator (MCG) in PLL Engaged External (PEE} mode Clock derived from and external crystal 8MHz Core clock = 48MHz, BusClock = 48MHz 2 ... Multipurpose Clock Generator (MCG) in Bypassed Low Power External (BLPE) mode Core clock/Bus clock derived directly from external crystal with no multiplication Core clock = 8MHz, BusClock = 8MHz*/
/*---------------------------------------------------------------------------- Define clock source values *----------------------------------------------------------------------------*/#if (CLOCK_SETUP == 0) #define CPU_XTAL_CLK_HZ 4000000u /* the external crystal or oscillator clock frequency in Hz */ #define CPU_XTAL32k_CLK_HZ 32768u /* the external 32k crystal or oscillator clock frequency in Hz */ #define CPU_INT_SLOW_CLK_HZ 32768u /* the slow internal oscillator clock frequency in Hz */ #define CPU_INT_FAST_CLK_HZ 4000000u /* the fast internal oscillator clock frequency in Hz */ #define DEFAULT_SYSTEM_CLOCK 47972352u /* Default System clock value */#elif (CLOCK_SETUP == 1) #define CPU_XTAL_CLK_HZ 8000000u /* the external crystal or oscillator clock frequency in Hz */ #define CPU_XTAL32k_CLK_HZ 32768u /* the external 32k crystal or oscillator clock frequency in Hz */ #define CPU_INT_SLOW_CLK_HZ 32768u /* the slow internal oscillator clock frequency in Hz */ #define CPU_INT_FAST_CLK_HZ 4000000u /* the fast internal oscillator clock frequency in Hz */ #define DEFAULT_SYSTEM_CLOCK 48000000u /* Default System clock value */ #elif (CLOCK_SETUP == 2) #define CPU_XTAL_CLK_HZ 8000000u /* the external crystal or oscillator clock frequency in Hz */ #define CPU_XTAL32k_CLK_HZ 32768u /* the external 32k crystal or oscillator clock frequency in Hz */ #define CPU_INT_SLOW_CLK_HZ 32768u /* Value the slow internal oscillator clock frequency in Hz */ #define CPU_INT_FAST_CLK_HZ 4000000u /* Value of the fast internal oscillator clock frequency in Hz */ #define DEFAULT_SYSTEM_CLOCK 80000000u /* Default System clock value */#endif /* (CLOCK_SETUP == 2) */
this is in the function SystemInit()
/* System clock initialization */#if (CLOCK_SETUP == 0) /* Switch to FEI Mode */ /* MCG->C1: CLKS=0,FRDIV=0,IREFS=1,IRCLKEN=1,IREFSTEN=0 */ MCG->C1 = (uint8_t)0x06u; /* MCG->C2: ??=0,??=0,RANGE=0,HGO=0,EREFS=0,LP=0,IRCS=0 */ MCG->C2 = (uint8_t)0x00u; /* MCG_C4: DMX32=1,DRST_DRS=1 */ MCG->C4 = (uint8_t)((MCG->C4 & (uint8_t)~(uint8_t)0x40u) | (uint8_t)0xA0u); /* MCG->C5: ??=0,PLLCLKEN=0,PLLSTEN=0,PRDIV=0 */ MCG->C5 = (uint8_t)0x00u; /* MCG->C6: LOLIE=0,PLLS=0,CME=0,VDIV=0 */ MCG->C6 = (uint8_t)0x00u; while((MCG->S & MCG_S_IREFST_MASK) == 0u) { /* Check that the source of the FLL reference clock is the internal reference clock. */ } while((MCG->S & 0x0Cu) != 0x00u) { /* Wait until output of the FLL is selected */ } /* SIM->CLKDIV1: OUTDIV1=0,OUTDIV2=0,OUTDIV3=1,OUTDIV4=1,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0 */ SIM->CLKDIV1 = (uint32_t)0x00110000u; /* Update system prescalers */#elif (CLOCK_SETUP == 1)/* Switch to FBE Mode */ /* OSC->CR: ERCLKEN=0,??=0,EREFSTEN=0,??=0,SC2P=0,SC4P=0,SC8P=0,SC16P=0 */ OSC->CR = (uint8_t)0x00u; /* SIM->SOPT2: MCGCLKSEL=0 */ SIM->SOPT2 &= (uint8_t)~(uint8_t)0x01u; /* MCG->C2: ??=0,??=0,RANGE=2,HGO=0,EREFS=1,LP=0,IRCS=0 */ MCG->C2 = (uint8_t)0x24u; /* MCG->C1: CLKS=2,FRDIV=3,IREFS=0,IRCLKEN=1,IREFSTEN=0 */ MCG->C1 = (uint8_t)0x9Au; /* MCG->C4: DMX32=0,DRST_DRS=0 */ MCG->C4 &= (uint8_t)~(uint8_t)0xE0u; /* MCG->C5: ??=0,PLLCLKEN=0,PLLSTEN=0,PRDIV=3 */ MCG->C5 = (uint8_t)0x03u; /* MCG->C5: PLLCLKEN=1 */ MCG->C5 |= (uint8_t)0x40u; /* Enable the PLL */ /* MCG->C6: LOLIE=0,PLLS=0,CME=0,VDIV=0 */ MCG->C6 = (uint8_t)0x00u; while((MCG->S & MCG_S_OSCINIT_MASK) == 0u) { /* Check that the oscillator is running */ } while((MCG->S & MCG_S_IREFST_MASK) != 0u) { /* Check that the source of the FLL reference clock is the external reference clock. */ } while((MCG->S & 0x0Cu) != 0x08u) { /* Wait until external reference clock is selected as MCG output */ } /* Switch to PBE Mode */ /* MCG->C1: CLKS=2,FRDIV=0,IREFS=0,IRCLKEN=1,IREFSTEN=0 */ MCG->C1 = (uint8_t)0x82u; /* MCG->C6: LOLIE=0,PLLS=1,CME=0,VDIV=0 */ MCG->C6 = (uint8_t)0x40u; /* Switch to PEE Mode */ /* MCG->C1: CLKS=0,FRDIV=0,IREFS=0,IRCLKEN=1,IREFSTEN=0 */ MCG->C1 = (uint8_t)0x02u; /* MCG->C5: ??=0,PLLCLKEN=0,PLLSTEN=0,PRDIV=3 */ MCG->C5 = (uint8_t)0x03u; /* MCG->C6: LOLIE=0,PLLS=1,CME=0,VDIV=0 */ MCG->C6 = (uint8_t)0x40u; while((MCG->S & 0x0Cu) != 0x0Cu) { /* Wait until output of the PLL is selected */ } while((MCG->S & MCG_S_LOCK_MASK) == 0u) { /* Wait until locked */ } /* SIM->CLKDIV1: OUTDIV1=0,OUTDIV2=0,OUTDIV3=1,OUTDIV4=1,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0 */ SIM->CLKDIV1 = (uint32_t)0x00110000u; /* Update system prescalers */ #elif (CLOCK_SETUP == 2) ... ...
changing some defines in the second part have no effect...these values have no reference to the other code or files..I just postet for the sake of completeness...
To change clock, I only have to change CLOCK_SETUP from 0 to 1 or 2
0 and 2 are working, 1 unfortunatly not.
I found out, that I have to change the modes from FEI to FBE to PBE to PEE to get the maximal core-frequenzy (96 MHz)...am I right ?
In uVision, I got the opportunity to manually change the registers -> but I always stuck by swtiching into PEE mode.The debug mode is exiting without an error.
Does anybody have some experience about this all? Or can anybody say why CLOCK_SETUP 1 is not working ?
Thanks in advance.
Regards, Philip
Solved! Go to Solution.
A service request gave me a answer:
it is possible to messure the frequency this way, but you have to divide it by 2.
"TRACE_CLKOUT is half of CPU clock"
so its everything correct. Thanks Brun.
I am running a bareboard setup and can not get my clocks and PIT to work correctly.
First is there code that sets up the K60 Tower with its 50Mhz OSC?
I need 96Mhz core, 48Mhz bus 24 Mhz flash and 48Mhz USB ciocks.
Could someone also step me through PIT setup..... I set it up now and it runs very slow :smileyhappy:
It seems that my system is running at 96Mhz from a LED toggle program I wrote and put it on scope, it looked like approx 20ns...... but PIT runs from bus clock right?
Please help!
THanks!
Is the PEE mode working on your controller?
I copied the configuration from CMSIS startup - so normaly, it should work :-/
The programm starts directly in debug mode...in all other CLOCL_SETUP modes, I have to start it manually...
I also cannot stop or reset the controller per software.
"Could not stop Cortex-M device! Please check the JTAG cable."
What does this mean?
does nobody have any experience? Are you all running your K60 in lowspeed?
Here again some code...
FEI -> FBE
/* Switch to FBE Mode */ /* OSC->CR: ERCLKEN=0,??=0,EREFSTEN=0, */ OSC->CR = (uint8_t)0x00u; /* SIM->SOPT2: MCGCLKSEL=0 TRACECLKSEL=1 */ SIM->SOPT2 = SIM_SOPT2_TRACECLKSEL_MASK; /* MCG->C2: ??=0,??=0,RANGE=2,HGO=0,EREFS=1,LP=0,IRCS=0 */ MCG->C2 = (uint8_t)0x24u; /* MCG->C1: CLKS=2,FRDIV=3,IREFS=0,IRCLKEN=1,IREFSTEN=0 */ MCG->C1 = (uint8_t)0x9Au; /* MCG->C4: DMX32=0,DRST_DRS=0 */ MCG->C4 &= (uint8_t)~(uint8_t)0xE0u; /* MCG->C5: PLLCLKEN=0,PLLSTEN=0,PRDIV=25(50MHz / 25 = 2MHz)*/ MCG->C5 = (uint8_t)0x18u; /* MCG->C5: PLLCLKEN=1 */ MCG->C5 |= (uint8_t)0x40u; /* Enable the PLL */ /* MCG->C6: LOLIE=0,PLLS=0,CME=0,VDIV=0 */ MCG->C6 = (uint8_t)0x00u; while((MCG->S & MCG_S_OSCINIT_MASK) == 0u) { /* Check that the oscillator is running */ } while((MCG->S & MCG_S_IREFST_MASK) != 0u) { /* Check that the source of the FLL reference clock is the external reference clock. */ } while((MCG->S & 0x0Cu) != 0x08u) { /* Wait until external reference clock is selected as MCG output */ }
FBE->PBE
PBE->FEI
/* Switch to PEE Mode */ /* MCG->C1: CLKS=0,FRDIV=0,IREFS=0,IRCLKEN=1,IREFSTEN=0 */ MCG->C1 = (uint8_t)0x02u; /* MCG->C5: ??=0,PLLCLKEN=0,PLLSTEN=0,PRDIV=25 */ MCG->C5 = (uint8_t)0x18u; /* MCG->C6: LOLIE=0,PLLS=1,CME=0,VDIV=50 (2MHz * 48 = 96MHz) */ MCG->C6 = (uint8_t)0x58u; while((MCG->S & 0x0Cu) != 0x0Cu) { /* Wait until output of the PLL is selected */ } while((MCG->S & MCG_S_LOCK_MASK) == 0u) { /* Wait until locked */ } /* SIM->CLKDIV1: OUTDIV1=0,OUTDIV2=1,OUTDIV3=3,OUTDIV4=1 */ SIM->CLKDIV1 = (SIM_CLKDIV1_OUTDIV1(0) | SIM_CLKDIV1_OUTDIV2(1) | SIM_CLKDIV1_OUTDIV3(3) | SIM_CLKDIV1_OUTDIV4(1));
Calculation:
50 MHz external reference clock deviced by PRDIV=25 --> 2 MHz input to PLL
2 MHz multiply VDIV=48 -->96 MHz to MCGOUTCLK
Core / System Clock = 96 MHz
Bus Clock = 48 MHz
after this, a simple LED programm should run...but it exit before
SIM->SCGC5 |= (1UL << 9); /* Enable Clock to Port A */
PORTA->PCR[28] = (1UL << 8); /* Pin is GPIO */
PTA->PDOR = (1 << 28);
PTA->PDDR |= (1 << 28);
That works fine with the K60 TWR:
/* MCG->C2: ??=0,??=0,RANGE=1,HGO=1,EREFS=1,LP=0,IRCS=0 */ MCG->C2 = MCG_C2_RANGE(1)|MCG_C2_HGO_MASK| MCG_C2_EREFS_MASK; /* MCG->C1: CLKS=2,FRDIV=2,IREFS=0,IRCLKEN=0,IREFSTEN=0 */ MCG->C1 = MCG_C1_CLKS(2)|MCG_C1_FRDIV(3); while((MCG->S & MCG_S_OSCINIT_MASK) == 0u) { /* Check that the oscillator is running */ } while((MCG->S & MCG_S_IREFST_MASK) != 0u) { /* Check that the source of the FLL reference clock is the external reference clock. */ } while((MCG->S & MCG_S_CLKST_MASK) != 0x08u) { /* Wait until external reference clock is selected as MCG output */ } /* MCG->C5: ??=0,PLLCLKEN=0,PLLSTEN=0,PRDIV=1 */ MCG->C5 = MCG_C5_PRDIV(0x17u); /* MCG->C6: LOLIE=0,PLLS=1,CME=1,VDIV=0 */ MCG->C6 = MCG_C6_CME_MASK|MCG_C6_PLLS_MASK; while(!(MCG->S & MCG_S_PLLST_MASK)) { /* Check that the oscillator is running */ } while(!(MCG->S & MCG_S_LOCK_MASK)) { /* Check that the source of the PLL reference clock is the external reference clock. */ } SIM->CLKDIV1 = SIM_CLKDIV1_OUTDIV1(0)| SIM_CLKDIV1_OUTDIV2(0)| SIM_CLKDIV1_OUTDIV3(1)| SIM_CLKDIV1_OUTDIV4(3); /* Update system prescalers */ /* MCG->C1: CLKS=2,FRDIV=0,IREFS=0,IRCLKEN=1,IREFSTEN=0 */ MCG->C1 &= ~MCG_C1_CLKS_MASK; while((MCG->S & MCG_S_CLKST_MASK) != 0x0Cu) { /* Wait until external reference clock is selected as MCG output */ }
K60P144M100SF2RM.pdf @ page586
Thank you for your answer.
in your code:
you mean PRDIV is 24, am I right?
Calculation:
50 MHz / 24 = 2,083333 MHz PRDIV=24
2,083333 MHz * 24 = 50 MHz VDIV = 24
Core/System Clock should be 50MHz
A short messurement with oscilloscope (before, I included this code):
/* Set the trace clock to the core clock frequency */ SIM->SOPT2 |= SIM_SOPT2_TRACECLKSEL_MASK; /* Enable the TRACE_CLKOUT pin function on PTA6 (alt7 function) */ PORTA->PCR[6] = ( PORT_PCR_MUX(0x7));
I got 25 MHz output on traceclk or Tower A36 pin...
Jumper J6 is on 1-2 state, so external reference clock is 50MHz
r u shure u can measure the frequency this way? (I also see only 25MHz)
but if I enter 50MHz for SysTick_Config(), and for Uart_init(), the timer and the baudrate is as expectet.
