Is bit-banding possible on the Kinetis? Any examples?
I read here: https://en.wikipedia.org/wiki/ARM_Cortex-M that bit-banding is optional on the Cortex M0+.
解決済! 解決策の投稿を見る。
You are right, it is optional and so bit-banding was not implemented in Kinetis-L because we have Bit Manipulation Engine (BME) which is much more powerful compared to bit-banding. You can find a chapter about it on each Kinetis L Reference Manual.
We have some examples in KL05/KL25 sample code, you can also refer to this THREAD.
Antonio
Specific 'Bit Banding', as per that ARM document, IS enabled in (at least) the Kinetis 'K' M4 devices. Pretty easy to use on peripherals; there is even a macro for it in the Kinetis headers as 'BITBAND_REG'. It is a little harder to use in RAM, mostly because the tools (compilers and linkers) won't help! But here is an example for a graphics display RAM, in this case using the least-significant-byte of each 32-bit word as screen data (so that the upper bits can be preset for a SPI DMA refresh).
So, you have to pre-allocate the space yourself (fixed location, subtracted from the linker-space):
#pragma location=0x2000EF00
__no_init u32_t Display_RAM[Y_PITCH*8]; //Pre-allocated fixed-space for Display RAM
//Necessary, in SRAM-U, to use bit-banding!
Then the SRAM bit-band macro is pretty similar to theirs:
#define BITBAND_SRAM_A(Addr,Bit) (0x22000000u + (((u32_t)(Addr) - (u32_t)0x20000000u)<<5) + (((u32_t)(Bit))<<2))
and here is a line-drawing process using that bit-banding to avoid detailed RMW of display RAM bits, preferring instead to just write each single bit
///Draw a line from (xstrt,ystrt) to (xfin,yfin) using 32bit dashing 'pattern'
// modified Bresenham algorithm, using ARM M4 'bit banding' RAM access to allow direct bit-writes (no RMW)
#define Y_PITCH 132
void OLED_Line(u16_t xstrt, u16_t ystrt, u16_t xfin, u16_t yfin, u32_t pattern)
s32_t eterm=0; //Error-term from fractional accumulations
///Some kind of 'set to half' should improve centering the steps
u16_t length; //# of dots to draw
s32_t diffx=xfin-xstrt;
s32_t diffy=yfin-ystrt;
u32_t _PTR_ offset;
s16_t stepx=1<<5; //Byte increment point for bit-band address
u16_t ybit;
if( xstrt > 127) xstrt = 127; //A little sanity checking!
if( xfin > 127) xfin = 127;
if( ystrt > 63) ystrt = 63;
if( yfin > 63) yfin = 63;
ybit = ystrt&7;
offset = &Display_RAM[xstrt];
offset += (ystrt>>3)*Y_PITCH; //8 bits of pixels per page, so add the page offset
offset = (u32_t _PTR_)BITBAND_SRAM_A(offset,ybit); //Convert to bit-band address, adding-in bit offset within byte for pixel row
diffx=xfin-xstrt;
diffy=yfin-ystrt;
if (diffx<0)
stepx=-stepx;
diffx=-diffx;
if (diffy<0)
diffy=-diffy;
if (diffx>diffy) //'mostly horizontal', move integer x, fractional y
length=diffx+1;
// eterm = diffy/2;
for (u16_t i=0;i<length;i++)
register u32_t tmp;
*offset=pattern; //LSB-only is written
tmp = (pattern&1)<<31; //Compiler is SMART -- makes a proper ROR out of this pair!!!
pattern = (pattern>>1) | tmp;
offset+=stepx;
eterm+=diffy;
if (eterm>diffx)
eterm-=diffx;
offset-=1;//<<2; //Each step in y moves to the next bit, BUT once we underflow the byte
ybit = (ybit-1)&7; // where bitcount in bitband address is *4
if(ybit == 7) // we must move to the LSB or MSB of the next row up/down.
offset -= (Y_PITCH<<5)-(8);//<<2); //To next bitband byte location, less the 8-bit-count already done
else //'mostly vertical', move integer y, fractional x
length=diffy+1;
// eterm = diffx/2;
register u32_t tmp;
eterm+=diffx;
if (eterm>diffy)
eterm-=diffy;
offset+=stepx;
}else
{ //Positive Y-direction:
length=diffx+1;
// eterm = diffy/2;
register u32_t tmp;
offset+=stepx;
eterm+=diffy;
if (eterm>diffx)
eterm-=diffx;
// Note: bitcount in bitband address is *4, but since 'offset' is a u32 pointer, this is accounted for
offset+=1;//<<2; //Each step in y moves to the next bit, BUT once we overflow the byte
ybit = (ybit+1)&7;
if(ybit == 0) // we must move to the LSB or MSB of the next row up/down.
offset += (Y_PITCH<<5)-(8);//<<2); //To next bitband byte location, less the 8-bit-count already done
length=diffy+1;
// eterm = diffx/2;
register u32_t tmp;
pattern = (pattern>>1) | tmp; //Rotate-right 1
ybit = (ybit+1)&7; // where bitcount in bitband address is *4
eterm+=diffx;
if (eterm>diffy)
eterm-=diffy;
offset+=stepx;
Antonio
Thank you. I also downloaded the FRDM-KL25Z and TWRKL25Z48M Sample Code Package and looked at the BME examples.
