FlexPWM setting for single PWM
967件の閲覧回数
waqasbutt121
I am using the flexPWM module of MKV561M0VLL24. I am configuring my controller with the following setting but it is not working
Note: The code is for generating a single PWM on PWM0_A2.
PWM0->OUTEN = PWM_OUTEN_PWMA_EN((1 << 2));
PWM0->SM[2].CTRL = PWM_CTRL_LDFQ(0) |
                                                PWM_CTRL_HALF(0) |
                                                PWM_CTRL_FULL(1) |
                                                PWM_CTRL_PRSC(5) |
                                                PWM_CTRL_LDMOD(1);
PWM0->SM[2].CTRL2 = PWM_CTRL2_INDEP_MASK |
                                       PWM_CTRL2_PWM23_INIT(0) |
                                       PWM_CTRL2_INIT_SEL(0) |
                                       PWM_CTRL2_FRCEN(0) |
                                       PWM_CTRL2_FORCE(0) |
                                       PWM_CTRL2_FORCE_SEL(0) |
                                       PWM_CTRL2_CLK_SEL(0);
PWM0->SM[2].INIT = 0;
PWM0->SM[2].VAL1 = 1999;
PWM0->SM[2].VAL0 = 999;
PWM0->SM[2].VAL2 = 0;
PWM0->SM[2].VAL3 = 599;
PWM0->MCTRL = PWM_MCTRL_LDOK((1 << 2));
PWM0->MCTRL |= PWM_MCTRL_RUN((1 << 2));
The CNT register of this channel appears to be going beyond the VAL1 limit (which shouldn't happen if values are correctly loaded) and no PWM is generated. Kindly help
タグ(3)
760件の閲覧回数
waqasbutt121
Problem Solved:
Fault Status was not clear. Clearing the fault status resolved the problem
PWM0->FSTS = PWM_FSTS_FFLAG(0xF);
Moreover there is a strange behaviour, If i write the LDOK field in MCTRL without reading the MCCTRL register, it doesn't update
