Hi, i am using kl25 series and i have configured FSL_USB_STACK for both USB_OTG and CDC. Using this configuration I have compiled and flashed into kl25 board. But after connecting USB to the device, device is not showing inside device manager.we refered below link http://mcuoneclipse.com/2012/10/07/tutorial-usb-cdc-with-the-kl25z-freedom-board/.
Hi Deepak,
are you using Kinetis Design Studio V2.0.0?
Erich
Hello Erich,
did you connect J21 jumper on the board?
If you already did it, I'm sorry.
Best regards.
Yasuhiko Koumoto.
there is no J21 jumper on the FRDM-KL25Z, or did I miss it?
I'm using the board with its default jumper settings/configurations.
Hello Erich,
really?
I am afraid the board had been revised.
Does your board have the below jumper?
Because no header for J21 is equipped and you should attach the header.
Yasuhiko Koumoto.
oh, I missed that jumper, sorry. So I do have this jumper *not* set.
