Hi I'm evaluating TWR-KM34Z50's 24bit SDADC, I wired both EXT_SD_ADP0 and EXT_SD_ADM0 to VSSA, and run afe_test, then I got values between 0x6df8 and 0x824a, it seems 13 bit shifting. Anything wrong in my configuration or is it normal?
Rome.
Solved! Go to Solution.
Hi Rome,
When using the AFE demo default setting, the AFE channel0 value with bigger shifting. Please check below FreeMaster scope copy:
Then I change the default AFE module setting with max. oversampling number and low down AFE module refer clock with below code:
AFE_ChanInit (CH0, AFE_CH_SWTRG_CCM_PGAOFF_CONFIG(DEC_OSR2048), 0, PRI_LVL0, NULL);
AFE_Init (AFE_MODULE_RJFORMAT_CONFIG(AFE_PLL_CLK, AFE_DIV256, 12288000));
After that, I will get below FreeMaster scope copy:
Wish it helps.
best regards,
Ma Hui
Hi Rome,
Wish it helps.
best regards,
Ma Hui
Thanks for the answer, the shifting reduced dramatically.
Rome.
