About accuracy of TWR-KM34Z50's 24bit SDADC
Search instead for
romehuang
Hi I'm evaluating TWR-KM34Z50's 24bit SDADC, I wired both EXT_SD_ADP0 and EXT_SD_ADM0 to VSSA, and run afe_test, then I got values between 0x6df8 and 0x824a, it seems 13 bit shifting. Anything wrong in my configuration or is it normal?
Rome.
Hui_Ma
Hi Rome,
When using the AFE demo default setting, the AFE channel0 value with bigger shifting. Please check below FreeMaster scope copy:
Then I change the default AFE module setting with max. oversampling number and low down AFE module refer clock with below code:
  AFE_ChanInit (CH0, AFE_CH_SWTRG_CCM_PGAOFF_CONFIG(DEC_OSR2048), 0, PRI_LVL0, NULL);
  AFE_Init     (AFE_MODULE_RJFORMAT_CONFIG(AFE_PLL_CLK, AFE_DIV256, 12288000));
After that, I will get below FreeMaster scope copy:
Wish it helps.
best regards,
Ma Hui
Hui_Ma
Hi Rome,
Wish it helps.
best regards,
Ma Hui
romehuang
Thanks for the answer, the shifting reduced dramatically.
Rome.
