unable to laugh initial demo
1,042件の閲覧回数
michelgaeta
Hello
I have just install FRDMK64F sdk, I try to run initial example and I get launch error.
Everything is compiling , I can run the factory 'hello word' on the board & putty
but I am not able to download any software
just getting : "an internal error occurred during : "launching hello_word_frdmK64f debug cmsisdap"
any one can help ?
970件の閲覧回数
DavidS
Hi Michel,
Two things for you to try:
1) after initial plug-in of USB cable and it enumerates, disconnect and reconnect.  I have seen that board needs changes for system to power up a second time before it runs correctly.
2) goto OpenSDA Serial and Debug Adapter|Freescale  and select your FRDM-K64F and try updating and/or using different debugger firmware (PEMicro or Segger).
David
