KDS Beta 1.0
Ubuntu 12.04 64-bit running in VirtualBox on a Win7 64-bit host.
I was able to install KDS and compile a PEx “blinky” version for FRDM-KL25Z. I can use the latest firmware to drag and drop the .s19 file onto the FRDM-KL25Z board after installing the latest bootloader and MSD files.
But I am unable to connect to opensda. I have installed the necessary drivers and ran the P&E script (setup.sh).
The debugger is recognized. It just won’t connect (see below for Debugger menu). It seems it can’t find the programming algorithm and the reason might be that “P&E” is not a legal Linux directory name.
I have contacted P&E but have not heard any response. It's been almost a week.
brad@brad-M4700:/opt/Freescale/KDS_1.0/eclipse/plugins/com.pemicro.debug.gdbjtag.pne_1.0.3.201403301338/lin/gdi$ ls -al
total 1608
drwxr-xr-x 3 root root 4096 Apr 8 12:53 .
drwxr-xr-x 3 root root 4096 Apr 8 12:53 ..
drwxr-xr-x 2 root root 65536 Apr 8 12:53 P&E
-rwxr-xr-x 1 root root 1570339 Mar 29 08:22 unit_ngs_arm_internal.so
brad@brad-M4700:/opt/Freescale/KDS_1.0/eclipse/plugins/com.pemicro.debug.gdbjtag.pne_1.0.3.201403301338/lin/gdi$ cd P&E
[1] 7181
bash: cd: P: No such file or directory
E: command not found
[1]+ Exit 1 cd P
Here is the terminal output from KDS:
P&E GDB Server, Version 2.02.00.03
Copyright 2014, P&E Microcomputer Systems Inc, All rights reserved
Loading library /opt/Freescale/KDS_1.0/eclipse/plugins/com.pemicro.debug.gdbjtag.pne_1.0.3.201403301338/lin/gdi/unit_ngs_arm_internal.so ... Done.
Command line arguments: -device=KL25Z128M4 -startserver -serverport=7224 -interface=OPENSDA -port=USB1 -speed=5000 -USE_CYCLONEPRO_RELAYS=0 -FORCE_MASS_ERASE=1
Device selected is kl25z128m4
User Specified Hardware Selection : Interface=OPENSDA and Port=USB1
Connecting to target.
OpenSDA detected - Flash Version 1.14
Forcing mass erase...
Device is KL25Z128M4.
Mode is In-Circuit Debug.
'Kinetis' is a registered trademark of Freescale.
(C)opyright 2012, P&E Microcomputer Systems, Inc. (www.pemicro.com)
API version is 101
PE-ERROR: Algorithm /opt/Freescale/KDS_1.0/eclipse/plugins/com.pemicro.debug.gdbjtag.pne_1.0.3.201403301338/lin/gdi/P&E/ not found
Target Disconnected.
PE-ERROR: Target XML File for kl25z128m4 not found
Server running Connection from "127.0.0.1" via 127.0.0.1
PE-ERROR: Target is not connected
Disconnected from "127.0.0.1" via 127.0.0.1
解決済! 解決策の投稿を見る。
I've just stumbled upon the very same issue. Quick strace session has shown that the gdb server process is trying to write to a file called /opt/Freescale/KDS_1.0.1/eclipse/plugins/com.pemicro.debug.gdbjtag.pne_1.0.4.201404181439/lin/gdi/P&E/pedebug_arm_kl25z128m4.add
and fails, because of denied access:
3079 open("/opt/Freescale/KDS_1.0.1/eclipse/plugins/com.pemicro.debug.gdbjtag.pne_1.0.4.201404181439/lin/gdi/P&E/pedebug_arm_kl25z128m4.add", O_RDWR|O_CREAT|O_TRUNC|O_LARGEFILE, 0666) = -1 EACCES (Permission denied)
In my case the problem was solved by chown/chmod of P&E directory.
I guess it failed, because the software was installed as root, and then I used a different user to run it, but I believe it should work in such a configuration (I expect software to write any files somewhere under my home directory). It's a pretty lame bug, and absolutely misleading error message.
Hi Brad,
I do not have your environment, but it works for me at least under Windows. I have pinged P&E so they could provide some more insights. I have pasted below as reference the console output on my machine.
Erich
P&E GDB Server, Version 2.02.00.01
Loading library C:\Freescale\KDS_1.0.1\eclipse\plugins\com.pemicro.debug.gdbjtag.pne_1.0.4.201404181439\win32\gdi\unit_ngs_arm_internal.dll ... Done.
Command line arguments: -device=KL25Z128M4 -startserver -serverport=7224 -interface=OPENSDA -port=USB1 -speed=5000 -USE_CYCLONEPRO_RELAYS=0 -FORCE_MASS_ERASE=0
API version is 101
Server running on 127.0.0.1:7224
Copyright 2012 P&E Microcomputer Systems,Inc.
Command Line :C:\Freescale\KDS_1.0.1\eclipse\plugins\com.pemicro.debug.gdbjtag.pne_1.0.4.201404181439\win32\pegdbserver_console -device=KL25Z128M4 -startserver -serverport=7224 -interface=OPENSDA -port=USB1 -speed=5000 -USE_CYCLONEPRO_RELAYS=0 -FORCE_MAS
CMD>RE
Initializing.
Target has been RESET and is active.
CMD>CM C:\Freescale\KDS_1.0.1\eclipse\plugins\com.pemicro.debug.gdbjtag.pne_1.0.4.201404181439\win32\gdi\P&E\kl25z128m4_pflash_pipeline.arp
Initializing.
Initialized.
;version 1.03, 07/17/2013, Copyright P&E Microcomputer Systems, www.pemicro.com [mk_128k_n_pflash_m0]
;device freescale, kl25z128m4, 1x32x32k, desc=pflash_pipeline
;begin_cs device=$00000000, length=$00020000, ram=$20000000
Loading programming algorithm ...
Done.
CMD>EM
Erasing.
Module has been erased.
Initializing.
Initialized.
Done.
CMD>PM
Programming.
Processing Object File Data ...
Programmed.
CMD>VC
Verifying object file CRC-16 to device ranges ...
block 00000000-000000BF ...
Ok.
block 00000400-000009AF ...
Ok.
Checksum Verification Successful. (Cumulative CRC-16=$D191)
CMD>RE
Initializing.
Preset breakpoint encountered.
Interrupt command received. Halting execution.
CTRL-C Pressed. Terminating Gracefully...
So I tried the latest version of KDS 1.0.1.
Still have problems. See my new post here: OpenSDA not working for KDS V1.0.1 in Linux.
Hi Brad,
Is it possible for you to give a try in Linux 12.04 LTS 32bits?
Garabo
It is possible. I have another PC with native Ubuntu 12.04 LTS 32-bit.
But have you confirmed it works in this environment? It takes a lot of time to set everything up properly.
--Brad
Hi Brad,
I got confirmation from the Program Manager that for Linux it is only 32 bit and NOT 64 bit. 64 bit will likely come in the KDS v2.0 release in October.
Garabo
I tested on Ubuntu 12.04 32-bit.
I am able to debug using OpenSDA and CMSIS-DAP.
Brad
