I've already a workaround to this problem, but wanted to share and see if anyone could help with the root cause
FYI, I'm using the TWR_MEM module with TWR-K60F120M kit, Kinetis Design Studio and Segger J-Link (basic).
I created a memory section called .mram @ 0x60000000. I then create a global variable in main.c as such:
byte __attribute__ ((section (".m_mram"))) mram_buf[MRAM_BUF_SIZE] = {0};
This compiles fine and the .map file shows that mram_buf is where I expect it to be; however, when debugging, the debugger locks up like so:
-----START CONSOLE OUTPUT-----
SEGGER J-Link GDB Server V4.84c Command Line Version
JLinkARM.dll V4.84c (DLL compiled Apr 16 2014 18:53:07)
-----GDB Server start settings-----
GDBInit file: none
GDB Server Listening port: 2331
SWO raw output listening port: 2332
Terminal I/O port: 2333
Accept remote connection: localhost only
Generate logfile: off
Verify download: on
Init regs on start: on
Silent mode: off
Single run mode: on
Target connection timeout: 5 sec.
------J-Link related settings------
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
------Target related settings------
Target device: MK60FN1M0xxx12
Target interface: SWD
Target interface speed: 1000kHz
Target endian: little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link ARM V8 compiled Nov 25 2013 19:20:08
Hardware: V8.00
S/N: 58004845
Checking target voltage...
Target voltage: 3.30 V
Listening on TCP/IP port 2331
Connecting to target...Connected to target
Waiting for GDB connection...Connected to 127.0.0.1
Reading all registers
Read 4 bytes @ address 0x00000000 (Data = 0x20000000)
Target interface speed set to 1000 kHz
Resetting target
Halting target CPU...
...Target halted (PC = 0x00001290)
R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
R12= 00000000, R13= 20000000, MSP= 20000000, PSP= 00000000
R14(LR) = FFFFFFFF, R15(PC) = 00001290
XPSR 01000000, APSR 00000000, EPSR 01000000, IPSR 00000000
CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
Select auto target interface speed (2000 kHz)
Flash breakpoints enabled
Semi-hosting enabled (VectorAddr = 0x08)
Semihosting I/O set to TELNET Client
Read 4 bytes @ address 0x00001290 (Data = 0xB082B580)
Downloading 488 bytes @ address 0x00000000 - Verified OK
Downloading 16 bytes @ address 0x00000400 - Verified OK
Downloading 16224 bytes @ address 0x00000410 - Verified OK
Downloading 9160 bytes @ address 0x00004370 - Verified OK
Downloading 4 bytes @ address 0x00006738 - Verified OK
Downloading 4 bytes @ address 0x0000673C - Verified OK
Downloading 2164 bytes @ address 0x00006740 - Verified OK
Downloading 48 bytes @ address 0x00006FB8 - Verified OK
Downloading 4 bytes @ address 0x60000000 - Verify failed
Writing register (PC = 0x000012a4)
Read 4 bytes @ address 0x000012A4 (Data = 0xB082B580)
Read 2 bytes @ address 0x00000E7E (Data = 0xF001)
WARNING: Failed to reset CPU. VECTRESET has confused core.
WARNING: CPU did not halt after reset.
WARNING: S_RESET_ST not cleared
ERROR: Error while identifying Cortex-M core.
Resetting target
...Target halted (PC = 0x00000F56)
R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000B38
R4 = 00000003, R5 = FFFFFF89, R6 = 00000000, R7 = 1FFFFFA8
R12= 00000000, R13= 1FFFFFA8, MSP= 1FFFFFA8, PSP= 00000000
R14(LR) = FFFFFFF9, R15(PC) = 00000F56
XPSR 01000003, APSR 00000000, EPSR 01000000, IPSR 00000003
Read 4 bytes @ address 0x00000F56 (Data = 0x73FFF6C1)
Reading 64 bytes @ address 0x1FFFFFC0
WARNING: Failed to read memory @ address 0x1FFFFFC0
Setting breakpoint @ address 0x00000E7E, Size = 2, BPHandle = 0x0000
WARNING: No more breakpoint resources left
Starting target CPU...
-----END CONSOLE OUTPUT-----
Now the workaround that I've found is to not initialize the memory at declaration as follows:
byte __attribute__ ((section (".m_mram"))) mram_buf[MRAM_BUF_SIZE];
This allows the debugger to run and I can verify that indeed I have access to this memory section via "mram_buf". So...I hope that might help someone/anyone who runs into this problem; however, I' wondering...does anyone know what's happening here (i.e. why initializing the buffer is causing the debugger lockup)?
Aaron
Solved! Go to Solution.
Hello Aaron:
If you or the linker itself initializes the buffer, those 0's appear in the s-record or binary file, and when the programming tool (in this case J-Link) tries to load those values, Flex Bus is not configured yet and it crashes.
You can indicate the linker not to initialize the ".m_mram" section with the NOLOAD directive. Check the next tutorial by colleague Erich Styger:
GNU Linker, can you NOT Initialize my Variable? | MCU on Eclipse
Hope this helps understanding the problem.
Regards!
Jorge Gonzalez
Hello Aaron:
Regards!
Jorge Gonzalez
That did it! Your explanation (and Erich's blog) make complete sense, thanks so much.
