1.8.0 版本的这个按钮,并不能 清除lvgl-simulator 目录下生成的临时文件,导致将工程移动到其他路径 编译报错,必须手动删除该文件夹才可以重新编译
Solved! Go to Solution.
Hi @ZYQ,
The 'Clean Generated File' operation will clean all files generated by 'Generate Code' operation, includes source codes, font files and image files.
We may consider add build clean in future release, thanks for your feedback.
Wenbin
Hi @ZYQ,
Wenbin
