about gui-guider1.8 version datetext model
Lfx
How can update datetext value by code,when I used to lv_label_set_text() function after update datetext attribute. datetext Unable to select date
EdwinHz
Hi @Lfx,
If I understand correctly, you claim that after changing the date value of a datetext widget with the lv_label_set_text() function, the date will not be able to be changed, or you will not be able to select the date again with the calendar. Am I understanding correctly?
I tried reproducing this issue, but I was not able to do so. On my side, it worked normally. If I changed the date using custom code and the lv_label_set_text() function, I was still able to open the calendar and change the date normally.
Could you please explain the process that you are doing in order to see the issue?
BR,
Edwin.
Lfx
thanks,I try do it again
