After the S32R294 chip is powered off and restarted enter IVORZ40_1_Handler
Jack_112233
If a DBC CAN message is sent from canoe, the exception interruption IVORZ40_1_Handler is entered after the mcu is powered off and restarted. If the none EB tresos MCAL hardware object configration message are sent and can hardware object message are sent when the power-on communication is normal, there is no problem. The premise is that mcal uses eb tresos configuration code, and the BSW portion above mcal is handwritten code.
What documents do you have to introduce this IVORZ40 1 Handler?
