I have found free IP cores for 68k processors on the web. Can we use those cores in commercial applications as a substitute for legacy 68k processor(s)? What are the legal implications?Does NXP/motorola still hold patent rights for 68k family(68000,68010, 68020 and so on)?
Please refer the webpage [IP-block Licensing], there listed 68K core IP.
NXP is licensing many functional IP blocks in various fields. An IP block is a reusable unit of logic, cell, or chip layout design and can be used as building block for various chip- and logic designs. By making this technology available NXP is opening up the opportunity for chip designers to leverage our world-class building blocks in a wide assortment of on-chip solutions. Several IP block licenses include relevant application software.
Please contact with your local NXP distributor about IP licensing.Thanks.
best regards,
Mike
Where exactly? That page lists:
There are no 68000 (or 68020 or 68300 or CPU32) cores listed there.
The 68000 (being asked about) CPUs are so old they were probably hand-taped, so I wouldn't expect NXP to have IP that would fit in an FPGA for them.
Tom
Hi Tom,
You are right. The [IP-block Licensing] program does not include 68K core.
68K core is quite old and I need to check with internal team about 68K core IP info.
Thank you all for the patience.
best regards,
Mike
I am looking for legal implications if we were to use rasberry Pi based emulator for 68k processor. Please clarify as buying new IP core is out of question.
