Hi experts,
I have an unexpected bihaviour on my board (LS1043ARDB-PA Rev. A) when testing GPIOs.
Using CodeWrior I load rcw_1600.bin (nor flash rcw generated by SDK2.0) and modify it to enable GPIO1_13 function (ASLEEP pin). I write the rcw to the NOR flash (bankv4) then reset on bankv4 (=> cpld reset altbank). I can see that the ASLEEP LED gets fired and holds this state permanentely. But any operation I perform on the GPIO1_13 (bit n°13 in the registers(?)) has no effect. Instead, the bit n°10 which is not implemented (?) acts on the LED. The log below is what I do from u-boot prompt.
My questions are.
- Are there hidden fucnctions controlled by GPIO registers or am I doing something wrong?
- What is the suggested way to test GPIOs on the LS1043arb (our product should use some GPIOs )?
Thanks in advance.
1) RCW as shown in the boot message
Reset Configuration Word (RCW):
00000000: 08100010 0a000000 00000000 00000000
00000010: 14550002 80004012 e0025000 c1002000
00000020: 00000000 00000000 00000000 0003cc00
00000030: 00000000 00001101 00000096 00000001
2) display GPIO1 registers >> The LED is ON
=> md 2300000
02300000: 00000000 00000000 00010400 00010400 ................
02300010: 00000000 00000000 00000000 00000000 ................
3) set bit10 as output (GPDIR) and display the result >> The LED gets OFF
=> mw.l 2300000 400
=> md 2300000
02300000: 00000400 00000000 00010000 00010400 ................
4) write to the data register and display the result >> The LED gets ON
=> mw.l 2300008 400
=> md 2300000
02300000: 00000400 00000000 00010400 00010400 ................
There is actually no problem. Some registers of the SoC are little endian while others are big endian...
