CW10 Duplicate Target Folder
1,377件の閲覧回数
WHookway
I have a M52259EVB board and have created a test application which builds and runs.  Within the same project I created a EVB51JM build configuration which also runs.  When I build the 51jm a folder is created called m51jmevb_... with the sources folder and the appropriately created files, s19, xMap, sources.mk etc.  If I build the 51jm a second time a new sub-folder is created within this same project with the same name, m51jmevb_....., this folder has a Sources subfolder and a subdir,mk file within it.  This build has rebuilt the sources.mk, objects.mk, makefile, and the .args file.  The elf, S19 and xMap file were not rebuilt.  The subdir.mk file has the following in it:
OBJ_SRCS_QUOTED += \"../m51jmevb_Int_Flash_Debug/Sources/main.obj"
OBJ_SRCS += \../m51jmevb_Int_Flash_Debug/Sources/main.obj
Any thoughts why this directory is being added?
Will
タグ(1)
3 返答(返信)
740件の閲覧回数
frankbaird
William,
Did you ever get this fixed? It seems I am having a very similar problem, over 5 years later.
740件の閲覧回数
J2MEJediMaster
Specialist I
This is part of the Eclipse build process with CodeWarrior. A second sub-directory, Sources, is made that contains a number of files such as *.mk, *.args,*.d and *.eln, that you have seen. A subdirectory based on the launch configuration and project name also appears, and this is where assorted make files and the final linked binary file appear.
---Tom
740件の閲覧回数
WHookway
Tom,
Thanks for the reply, but let me clarify.  I end up with 3 Sources folders, and the third one only appears after a second build from a clean.  So after the first build I have the following directory structure:
mqxTest2
        Sources
            main.args
            main.d
            main.obj
            subdir.mk
        makefile
        mqxTest2_51.args
        mqxTest2_51.elf
        mqxTest2_51.elf.s19
        mqxTest2_51.elf.xMAP
        objects.mk
        sources.mk
    m52259evb_Ext_MRAM_Debug
    m52259evb_Int_Flash_Debug
    m52259evb_Int_Flash_Release
    Project_Settings
    Sources
        main.c
        main.h
        rtcs_init.c
        usbd_init.c
*******The above all looks fine, but if I do another build (without a clean) I get the following added:
mqxTest2
        m51jmevb_Int_Flash_Debug   ***
            Sources                                     ***
               subdir.mk                               ***
        Sources
            main.args
            main.d
            main.obj
            subdir.mk
        makefile                                       File rebuilt
        mqxTest2_51.args                    File rebuilt
        mqxTest2_51.elf                        File untouched
        mqxTest2_51.elf.s19                File untouched
        mqxTest2_51.elf.xMAP              File untouched
        objects.mk                                   File rebuilt
        sources.mk                                 File rebuilt
    All else is the same
It is the addition of the 2 directories and the one file that I don't understand that are being added
on the subsequent build.  Why would a subsequent build ever add anything new to the build?
Will
