Where can I download the USB Driver for the CodeWarrior TAP?
1,103 次查看
jeffhodges
When I plug in the device to a Windows machine, the driver is not found. A USB connection is needed to set a default IP address.
标签 (1)
3 回复数
911 次查看
addiyi
The CWTAP drivers are available in ccs folder (ccs\drivers\usb\), after CodeWarrior is installed.
Adrian
911 次查看
jeffhodges
Does the USB driver work on Windows 7?
From the readme.txt:
CodeWarrior USB Device Driver Manual Installation:
911 次查看
addiyi
Yes, ccs driver works on windows 7.
Adrian
