Sqaure root function in assembly language:
2,383 次查看
RohitSinghal
In order to handle performance issue, i require assembly code for sqaure root function that will boost the
over all system performance providing better results.
Regds,
Rohit
标记 (1)
963 次查看
CompilerGuru
There are a few important details missing in the question.
First, for which processor is this, for a S08 or S12 (or XGATE or RS08 or CF)?
Then on which kind of values (floating point, int, long, limited value range, complex numbers,...)?
ANSI C provides a floating point one only, so if you need an integral one, then
here's a C implementation by bigmac using a new Newton algorithm:
http://forums.freescale.com/freescale/board/message?board.id=16BITCOMM&message.id=6411
964 次查看
CompilerGuru
963 次查看
RohitSinghal
Thanks for the info.,
This code is required for flexis AC series of controller for S08 as well as CF processor.
It is basicly used for handling floating point numbers.
Regds,
Rohit
