HCS08 TIM simulation problem
2,466件の閲覧回数
joerg
I try to simulate the output compare function for TIM1 of GB32/60, RC8 and QD4 MPUs.
But in the simulator the TIM does not trigger an interrupt. If i connect a MPU with the BDM it works just fine. The simulation of a TOF interrupt works in the full chip simulation. Is this a known problem (i noticed this behavior for CW3.1, CW3.2, CW5.0 and CW5.1!!)
Thanks Joerg
Message Edited by joerg on 2007-01-0112:30 PM
タグ(1)
900件の閲覧回数
CrasyCat
Specialist III
Hello
You need to submit a service request  for that.
This is an issue in P&E simulation module.  You can log that defect either with Freescale support or
directly with P&E.
To log the issue with Freescale please go to following URL:
and click on "Submit a service request"
To log the issue with P&E use following URL:
Note that Freescale support personal will anyway have to log that with P&E.
CrasyCat
3 返答(返信)
901件の閲覧回数
CrasyCat
Specialist III
Hello
directly with P&E.
CrasyCat
900件の閲覧回数
joerg
Thanks CrazyCat
i have put the service request on the freescale support page:
Saluti Joerg
900件の閲覧回数
Phoenix
This bug will be fixed in v5.2 update patch. It should be released at the end of January.
