I have issue on compiling project . There is no problem compiling on other computer ,same project ,same builder setting ,same IDE version V11.1 . But when I compile it ,it failed .
what shows in console as below :
builder setting as below:
And files are as below :
Does anyone knows why ? So strange .I checked paths and symbols ,it contained source files correctly ,just file : full_project_build is not contained in the path, it is not source file, I don't know what is that . Thank you .
Hello Alondra Ou
Can you tell me the part number that you are using?
I suggest you to try another workspace? Also make sure that your machine has installed the mingw compiler.
Let me know if this is helpful, if you have more questions do not hesitate to ask.
Omar
