code warrior 11.1 with multi-link breakpoint won't go further.
lsh9640
Hi. I have a codewarrior 11.1 version and a multi-link universal to debug S12Z core microcontroller.
when I use break function with setting breakpoint at some line, it stops at that line. however it doesn't go further eventhough I kept clicking "resume" button. This is very weird because it does not happen every time but only with some line with increment of some variable or etc.  it is not because of reset problem. Any idea why? I mean.. when I use "Refresh while running" function, it worked very well and I could see the line is actually executed and working no problem.
ZhangJennie
SIHUN LEE
Is this issue only in one project or a common issue in all project?
Could you please send screenshot of this issue? How to reproduce?
Jun Zhang
