Codewarrior v.10.7
I go into Calc.c and configure the code to meet the requirements.
Ctrl+S, Ctrl+B, debug.
Everything is fine.
then Flash File to Target with Save as Target Task (and assign a name, let's call this Target Task 1.abs
Flash file to target.
Everything is fine.
then Execute Target Task 1.abs on additional targets (of the same MCU part number)
Target Task flashes file to target.
Everything is fine.
then I go back into Calc.c and reconfigure the code to meet other requirements.
Everything is fine.
then Flash File to Target with Save as Target Task (and assign a new name, let's call this Target Task 2.abs
Everything is fine.
then Execute Target Task 2.abs on additional targets (of the same MCU part number)
Everything is fine.
Now here's the problem.
I come back and Execute Target Task 1.abs on targets but I end up with Target Task 2.abs on the target.
It seems regardless of which Target Task I Execute, I end up with the last .abs file I saved on the system.
Is there a configuration setting within Codewarrior which I'm overlooking?
What could I possibly be doing wrong?
This makes no sense.
Many thanks in advance.
Thanks Alice but that's exactly what we're doing.
It seems no matter which Target Task we select, the file which goes on the chip is the last file configured, regardless of which file we select.
Hi Brandon,
How do you know "the file which goes on the chip is the last file configured" ?
Also does the "file " meaning the binary file that you want to flash into chip ?
Alice
Because each file has different behavior.
If 1.abs flashes a LED and 2.abs sounds a buzzer, and I flash 1.abs to the MCU, I get a buzzer and no flashing LED.
That may be the problem. When I build the flash tasks I'm only saving in the workspace. When it flashes I get what's in the workspace, even if it changed since I saved the task. I'm going to start savings tasks in a separate folder. Thanks for the guidance.
Hi Brandon,
Thanks ok.
Alice
Hello Brandon Doucette,
You can choose Tasks on "Target Tasks" view :
You can also choose on below:
Hope it helps
Alice
