Hi everybody,
I'm new in this community so I apologize in advance if I'm wrong to make this request.
I'm using a mwct1003 with CodeWarrior and I've a problem with interrupt handling.
I have created a new MCU project selecting the mwct1003. I've set up my module registers (Timer A2) to generate an interrupt and I've seen that the interrupt vector table is managed in MWCT10xx_vector.asm file; the module interrupt flag is asserted correctly but the service routine is not executed.
May anyone know if there are any special steps to follow to execute the ISR?
已解决! 转到解答。
Please check the bit in Interrupt Priority Register for Timer A2, whether the IRQ is disabled? And please also compare its settings with the bit I0-I1 in SR register.
Fiona Kuang
Technical Information & Commercial Support
Fiona Kuang
