i used wct1013a.
I have the boot loader code.
I know that the boot loader jumps directly to the code of the application.
But what if you want to upgrade other firmware on the bootload?
How do I clear my application code?
Help me .. please ..
Hi, Semikim,
Regarding your question, I suggest you refer to the an4759.pdf located at the link:
https://www.nxp.com/docs/en/application-note/AN4759.pdf
The bootloader code is put at the top of program flash, located at from 0x1F400 to 0x1FFFF, after Reset, the DSC jump to the bootloader code, it monitor the SCI port, if it can not detect the SCI character until DelayTime, it will jump to application code, the application code Start Address is put at the address 0x1F3FD.
Hope it can help you
Xiangjun Rong
Hi Xiang Jun Rong,
Thank you! The application note is really helpful on the MCWT1003A.
Best regard
Joshua
Field Application Engineer
WT Microelectronics Singapore Pte Ltd
2 Serangoon North Ave 5, #05-01 Singapore 554911
Tel : +65 6853 1788 ext: 1067
Mobile : +65 9146 9763
Email : Joshua.Hong@wtmec.com<mailto:Joshua.Hong@wtmec.com>
