Range check error
Range check error
3,322件の閲覧回数
Dime
I am using Code Warrior with a 56F8323. I recently upgraded my Code Warrior IDE to V7.3 I then installed the two patches available for the Processor Expert Plug-in. Now whenever I try to load one of my existing projects or start a new project I get the "Range check error" message. Has anyone seen this before? Any ideas will be greatly appreciated.
タグ(1)
2 返答(返信)
735件の閲覧回数
BAUR
From version 6.xx to 7.xx the defined flash address in the header file of the flash-bean is not correct.
Procedure:
mark preserve user changes in  IDE-settings preocessor expert / project options
change in header file IFsh1.h
DATA_FLASH_START to 4096
DATA_FLASH_END     to 8192
do generate code and compile all new
best regards Baur
735件の閲覧回数
rmpratt
Where is the flash-bean header file IFsh1 in Windows XP?
I am using an evaluation version of 8.2 and a purchased version of 7.3 with the same "range check error."
So I can change this constant.
