Raghu Sorab wrote:David, I didnt get your sentence viz.. hard tied to ground. What does this mean
Actually I never said "to ground".
I meant that it was shorted to Vdd or Vss. Probably due to it being meant to be an input with a switch on it or something, but it got configured as an output and driven the other way.
That's all!
Regards David
Hi Ed,
Unfortunately for you, in my experience, nearly all the time, after MCU failure you end up with a space heater (low ohms from + to -).
PCB shorts - solder shorts - accidents that short i/o to supply or other power sources configuring pins as outputs when the pin is hard tied all mostly will do this. You find and fix this but its too late for your MCU.
Regards David
