Undesired FLASH protection on MC9S08QB4
benthie
Hey everybody,
my current application uses the flash programming routines from AN3942. At some point my program writes data to the flash (0xFFC0 - 0xFFFF). Everything works fine so far, the data is where I want it to be and when I debug the controller, the FOPT register tells me, that the flash is unsecured (FOPT = 0xC2).
If I stop my program and debug it again, then the "device is secured"-dialog pops up.
Does anybody has an idea, at which point the securing happens?
Ben
benthie
I found the problem. I erased the NVOPT bits due to a page erase and did not set the SEC00 bit back to 0. Ref.Manual p.55.
Thank you anyway.
Ben
benthie
Thank you anyway.
Ben
