Hello
That message is generated when you have enabled some triggers on the DBG module.
In the connection menu (MultilinkCyclonePro, GDI, .....) select "Trigger Module Settings".
There are probably some triggers defined in the Trigger settings tab.
Delete the triggers if you do not want to see the message again.
CrasyCat
