I am not getting interrupt in input capture mode. I posted my code below , Please help someone
#pragma CODE_SEG __NEAR_SEG NON_BANKED
interrupt void IC0_ISR(void)
// new_capture = TC0; //save the value of input capture register
LCD_Cmd(0x80);
PORTA = 0xFF;
t[i]=TC0;
i++;
if(i==2) {
i=0;
// 6.0742270546073012209196379760675e-8
time_interval=(t[1]-t[0]);
time_period=(float)(0.0000256* time_interval);
frequency= 1/time_period;
sprintf(buffer,"%f",frequency);
for(j=0;j<4;j++)
LCD_Data(buffer[j]);
TFLG1 = 0x01; //clear interrupt flag
interrupt void TOI_ISR(void)
TFLG2 = 0x80; //clear interrupt flag
unsigned int TM;
/* User includes (#include below this line is not maintained by Processor Expert) */
void main(void)
/* Write your local variable definition here */
/*** Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/
PE_low_level_init();
/*** End of Processor Expert internal initialization. ***/
/* Write your code here */
LCDIni();
// LCD_Cmd(0x01);
LCD_Cmd(0x80);
LCD_Data('T');
PPST_PPST0 = 0; //set pull-up
PERT_PERT0 = 1; //enable pull-up
TSCR1 = 0xE7; //enable timer, stop timer during wait and freeze, disable fast flag clear
TIOS_IOS0 = 0; //channel 0 as an input capture
TCTL4 = 0x01; //capture on rising edge
TIE_C0I = 0x01; //enable interrupt on channel 1
TSCR2 = 0x80; //timer overflow interrupt enable, timer prescaler is 0
for(;;){}
/*** Processor Expert end of main routine. DON'T WRITE CODE BELOW!!! ***/
/*** Processor Expert end of main routine. DON'T MODIFY THIS CODE!!! ***/
} /*** End of main routine. DO NOT MODIFY THIS TEXT!!! ***/
