Refering to Example 15, ISR Code for MC9S08QG8 and ......, I do not see any code that checks for I2C ACK from the slave when the micro sends data to the slave. Did the author leave this out, or am I misunderstanding something?
However, in the code using polling (yecch), I do see appropriate checks for ACKs from the slave.
I guess the real question is...if the author left ack checking out of interrupt driven method, well, was there some hardware problem that the author chose to avoid?
