Hey,
Thank your for reply.
My answers/questions in blue below.
Unfortunately, Once secure boot is enabled, we can't disable it.
OK for that.
did you download sb file with "blhost -p COMxx receive-sb-file " successfully? If yes, I just consult your problem with my SE colleague, it can print to uart without issue.
Yes it worked for the first time but once i want to update another image (write-memory) i can't, usually to fix it i erase-all memory and i unlock the write-memory but this time i get this error : "Response status = 10001 (0x2711) Command disallowed when security is enabled." ?
I will take the opportunity to ask you some others questions that I ask myself for the moment :
1- If I understood correctly, we can't debug once secure boot is enabled, therefore we can't talk about secure debug too ?
2- I don't know how secure boot ROM it works because i don't have access, but in this sense can you confirm that the ROM code doesn't enable TZEN for SB security features ?
3- Last question but not least, in your SDK last release you provide TFM implementation ? Can you please explain the perspectives of this implem and the eventual use cases ?
I mean today your SB doesn't relies to PSA-RoT so i can't understand if your are planing to integer in SB or others appli ?
