Task #6 - Customize the image
Don't forget to update your source code.
How to customize the image
Enter <yocto>/source and find any image available:
$ find -name *image*.bb
./meta-fsl-demos/recipes-fsl/images/fsl-image-gui-sdk.bb
./meta-fsl-demos/recipes-fsl/images/fsl-image-test.bb
./meta-fsl-demos/recipes-fsl/images/fsl-image-gui.bb
./meta-fsl-demos/recipes-qt/images/qt-in-use-image.bb
./meta-fsl-demos/recipes-qt/images/qte-in-use-image.bb
./meta-openembedded/meta-initramfs/recipes-bsp/images/initramfs-kexecboot-klibc-image.bb
./meta-openembedded/meta-initramfs/recipes-bsp/images/initramfs-kexecboot-image.bb
./meta-openembedded/meta-oe/recipes-support/imagemagick/imagemagick_6.7.5.bb
./meta-openembedded/meta-oe/recipes-multimedia/libsdl-image/libsdl-image_1.2.12.bb
./poky/meta-hob/recipes-core/images/hob-image.bb
./poky/meta-skeleton/recipes-multilib/images/core-image-multilib-example.bb
./poky/meta/recipes-devtools/mkelfimage/mkelfimage_svn.bb
./poky/meta/recipes-sato/images/core-image-sato-dev.bb
./poky/meta/recipes-sato/images/core-image-sato.bb
./poky/meta/recipes-sato/images/core-image-sato-sdk.bb
./poky/meta/recipes-qt/images/qt4e-demo-image.bb
./poky/meta/recipes-core/images/core-image-minimal.bb
./poky/meta/recipes-core/images/core-image-base.bb
./poky/meta/recipes-core/images/core-image-minimal-dev.bb
./poky/meta/recipes-core/images/core-image-minimal-initramfs.bb
./poky/meta/recipes-core/images/build-appliance-image.bb
./poky/meta/recipes-core/images/core-image-minimal-mtdutils.bb
./poky/meta/recipes-extended/images/core-image-lsb-sdk.bb
./poky/meta/recipes-extended/images/core-image-basic.bb
./poky/meta/recipes-extended/images/core-image-lsb-dev.bb
./poky/meta/recipes-extended/images/core-image-lsb.bb
./poky/meta/recipes-graphics/images/core-image-directfb.bb
./poky/meta/recipes-graphics/images/core-image-x11.bb
./poky/meta/recipes-graphics/images/core-image-clutter.bb
./poky/meta/recipes-graphics/xcb/xcb-util-image_0.3.9.bb
./poky/meta/recipes-bsp/u-boot/u-boot-mkimage_2012.04.01.bb
./poky/meta/recipes-bsp/u-boot/u-boot-mkimage_2011.06.bb
./poky/meta/recipes-bsp/u-boot/u-boot-mkimage_2011.03.bb
./poky/meta/recipes-rt/images/core-image-rt-sdk.bb
./poky/meta/recipes-rt/images/core-image-rt.bb
The above images (and packages with 'image' in file name) may be used as a base image, where new packages may be added, or example of new images.
bitbake -s  shows any *available* package locally. Grep for the name of desired package:
$ bitbake -s | grep calibrat
calibrateproto                      :0.0+gitAUTOINC+1da6fd1e2c7a49648245c98481fabea8b9690a8c-r2
libxcalibrate                       :0.0+gitAUTOINC+209d83af61ed38a002c8096377deac292b3e396c-r0
xinput-calibrator                   :0.7.5+gitAUTOINC+c01c5af807cb4b0157b882ab07a893df9a810111-r1
For example, the package name is xinput-calibrator, in order to include this package this would be the string needed.
The dependency tree is shown with
$ bitbake -g fsl-image-test
For the fsl-image-test. Or any other image
Include the package name on the image definition file.
$ cd meta-fsl-demos/
$ vim recipes-fsl/images/fsl-image-test.bb
Include the package name on IMAGE_INSTALL list:
IMAGE_INSTALL += " \
    packagegroup-fsl-gstreamer \
    packagegroup-fsl-tools-testapps \
    packagegroup-fsl-tools-benchmark \
xinput-calibrator \
In order to include the package on any image, configure conf/local.conf file the as the following:
MACHINE ??= 'imx6qsabresd'
DISTRO ?= 'poky'
PACKAGE_CLASSES ?= "package_rpm"
EXTRA_IMAGE_FEATURES = "debug-tweaks tools-sdk"
USER_CLASSES ?= "buildstats image-mklibs image-prelink"
PATCHRESOLVE = "noop"
CONF_VERSION = "1"
BB_NUMBER_THREADS = '8'
PARALLEL_MAKE = '-j 8'
ACCEPT_FSL_EULA = "1"
CORE_IMAGE_EXTRA_INSTALL += "xinput-calibrator"
And then
$ bitbake fsl-image-test
In order to add debug or native builder include on conf/local.conf:
EXTRA_IMAGE_FEATURES += "tools-sdk"
Every image created after that will include development tools. The same may be included in any bb image file.
From Poky description:
'tools-sdk" - Adds development tools such as gcc, make, pkgconfig and so forth.
"dev-pkg" - Adds -dev packages for all installed packages. This is useful if you want to develop against the libraries in the image.
"tools-debug" - Adds debugging tools such as gdb and strace.
If you don't like command line, or you prefer a window-like interface, you can take a look on HOB.
See hob documentation https://www.yoctoproject.org/documentation/hob-manual
See getting started video for hob Introducing Hob - YouTube
Go to Yocto Training - HOME
Go to Task #5 - Kernel
コメント
perhaps, in the process of debugging, it is useful to have unstripped libraries in the image, which is enabled in the conf/local.conf by:
INHIBIT_PACKAGE_STRIP = "1"
Rather than hacking at fsl-image-test.bb it may be better to create a client layer e.g.
meta-mylayer/recipes-mylayer/images/mylayer-image-test.bb:
include recipes-fsl/images/fsl-image-test.bb
    xinput-calibrator \
export IMAGE_BASENAME = "mylayer-image-test"
How can I add a touch screen like this: http://boundarydevices.com/products/7-800x480-display/ to the image? Do I have to add a driver? At the moment I'm using the fsl-image-gui-imx6sabreauto
The screen is already working but the touch does not :smileysad:
By the way: the mentioned layer built perfectly from scratch in 8 hours on my intel centrino duo on Ubuntu 12.04 WITHOUT patching anything :smileyhappy:
Bye bye LTIB...
%3CLINGO-SUB%20id%3D%22lingo-sub-1129220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%BF%E3%82%B9%E3%82%AF%20%236%20-%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%BF%98%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E7%94%BB%E5%83%8F%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CYOCTO%3E%2Fsource%20%E3%81%A8%E5%85%A5%E5%8A%9B%E3%81%97%E3%80%81%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E7%94%BB%E5%83%8F%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%99%E3%80%82%3C%2FYOCTO%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20%E6%A4%9C%E7%B4%A2%20-name%20*image*.bb%3C%2FP%3E%0A%3CP%3E.%2Fmeta-fsl-demos%2Frecipes-fsl%2Fimages%2Ffsl-image-gui-sdk.bb%3C%2FP%3E%0A%3CP%3E.%2Fmeta-fsl-demos%2Frecipes-fsl%2Fimages%2Ffsl-image-test.bb%3C%2FP%3E%0A%3CP%3E.%2Fmeta-fsl-demos%2Frecipes-fsl%2Fimages%2Ffsl-image-gui.bb%3C%2FP%3E%0A%3CP%3E.%2Fmeta-fsl-demos%2Frecipes-qt%2Fimages%2Fqt-in-use-image.bb%3C%2FP%3E%0A%3CP%3E.%2Fmeta-fsl-demos%2Frecipes-qt%2Fimages%2Fqte-in-use-image.bb%3C%2FP%3E%0A%3CP%3E.%2Fmeta-openembedded%2Fmeta-initramfs%2Frecipes-bsp%2Fimages%2Finitramfs-kexecboot-klibc-image.bb%3C%2FP%3E%0A%3CP%3E.%2Fmeta-openembedded%2Fmeta-initramfs%2Frecipes-bsp%2Fimages%2Finitramfs-kexecboot-image.bb%3C%2FP%3E%0A%3CP%3E.%2Fmeta-openembedded%2Fmeta-oe%2Frecipes-support%2Fimagemagick%2Fimagemagick_6.7.5.bb%3C%2FP%3E%0A%3CP%3E.%2Fmeta-openembedded%2Fmeta-oe%2Frecipes-multimedia%2Flibsdl-image%2Flibsdl-image_1.2.12.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta-hob%2Frecipes-core%2Fimages%2Fhob-image.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta-skeleton%2Frecipes-multilib%2Fimages%2Fcore-image-multilib-example.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-devtools%2Fmkelfimage%2Fmkelfimage_svn.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-sato%2Fimages%2Fcore-image-sato-dev.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-sato%2Fimages%2Fcore-image-sato.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-sato%2Fimages%2Fcore-image-sato-sdk.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-qt%2Fimages%2Fqt4e-demo-image.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-core%2Fimages%2Fcore-image-minimal.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-core%2Fimages%2Fcore-image-base.bb%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-core%2Fimages%2Fcore-image-minimal-dev.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-core%2Fimages%2Fcore-image-minimal-initramfs.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-core%2Fimages%2Fbuild-appliance-image.bb%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-core%2Fimages%2Fcore-image-minimal-mtdutils.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-extended%2Fimages%2Fcore-image-lsb-sdk.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-extended%2Fimages%2Fcore-image-basic.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-extended%2Fimages%2Fcore-image-lsb-dev.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-extended%2Fimages%2Fcore-image-lsb.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-graphics%2Fimages%2Fcore-image-directfb.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-graphics%2Fimages%2Fcore-image-x11.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-graphics%2Fimages%2Fcore-image-clutter.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-graphics%2Fxcb%2Fxcb-util-image_0.3.9.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-bsp%2Fu-boot%2Fu-boot-mkimage_2012.04.01.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-bsp%2Fu-boot%2Fu-boot-mkimage_2011.06.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-bsp%2Fu-boot%2Fu-boot-mkimage_2011.03.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-rt%2Fimages%2Fcore-image-rt-sdk.bb%3C%2FP%3E%0A%3CP%3E.%2Fpoky%2Fmeta%2Frecipes-rt%2Fimages%2Fcore-image-rt.bb%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%20(%E3%81%8A%E3%82%88%E3%81%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%E3%81%AB%20'image'%20%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8)%20%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%BE%8B%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Ebitbake%20-s%3C%2FSTRONG%3E%20%E3%81%AF%E3%80%81%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%81%A7%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E4%BB%BB%E6%84%8F%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%9B%AE%E7%9A%84%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E5%90%8D%E5%89%8D%E3%81%AE%20grep%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20bitbake%20-s%20%7C%20grep%20calibrat%3C%2FP%3E%0A%3CP%3Ecalibrateproto%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A0.0%2BgitAUTOINC%2B1da6fd1e2c7a49648245c98481fabea8b9690a8c-r2%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%0A%3CP%3Elibxcalibrate%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A0.0%2BgitAUTOINC%2B209d83af61ed38a002c8096377deac292b3e396c-r0%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%0A%3CP%3Exinput-calibrator%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3A0.7.5%2BgitAUTOINC%2Bc01c5af807cb4b0157b882ab07a893df9a810111-r1%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E5%90%8D%E3%81%AF%20%3CSTRONG%3Exinput-calibrator%3C%2FSTRONG%3E%20%E3%81%A7%E3%80%81%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E5%90%AB%E3%82%81%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E6%96%87%E5%AD%97%E5%88%97%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20bitbake%20-g%20fsl-image-test%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Efsl-image-test%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%E4%BB%96%E3%81%AE%E7%94%BB%E5%83%8F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E5%AE%9A%E7%BE%A9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E5%90%8D%E3%82%92%E5%90%AB%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20cd%20meta-fsl-demos%2F%3C%2FP%3E%0A%3CP%3E%24%20vim%20recipes-fsl%2Fimages%2Ffsl-image-test.bb%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E5%90%8D%E3%82%92%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E5%90%AB%E3%82%81IMAGE_INSTALL%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3EIMAGE_INSTALL%20%2B%3D%20%22%20%5C%3C%2FP%3E%0A%3CP%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97-FSL-gstreamer%20%5C%3C%2FP%3E%0A%3CP%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%20%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%20FSL%20%E3%83%84%E3%83%BC%E3%83%AB%20%E3%83%86%E3%82%B9%E3%83%88%20%E3%82%A2%E3%83%97%E3%83%AA%20%5C%3C%2FP%3E%0A%3CP%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97-fsl-tools-benchmark%20%5C%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%20xinput-calibrator%20%5C%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%22%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E4%BB%BB%E6%84%8F%E3%81%AE%3C%2FSTRONG%3E%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E5%90%AB%E3%82%81%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81conf%2Flocal.conf%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3EMACHINE%20%3F%3F%3D%20'imx6qsabresd'%3C%2FP%3E%0A%3CP%3EDISTRO%20%3F%3D%20'poky'%3C%2FP%3E%0A%3CP%3EPACKAGE_CLASSES%20%3F%3D%20%22package_rpm%22%3C%2FP%3E%0A%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%20%22debug-tweaks%20tools-sdk%22%3C%2FP%3E%0A%3CP%3EUSER_CLASSES%20%3F%3D%20%22buildstats%20image-mklibs%20image-prelink%22%3C%2FP%3E%0A%3CP%3EPATCHRESOLVE%20%3D%20%22noop%22%3C%2FP%3E%0A%3CP%3ECONF_VERSION%20%3D%20%221%22%3C%2FP%3E%0A%3CP%3EBB_NUMBER_THREADS%20%3D%20'8'%3C%2FP%3E%0A%3CP%3EPARALLEL_MAKE%20%3D%20'-j%208'%3C%2FP%3E%0A%3CP%3EACCEPT_FSL_EULA%20%3D%20%221%22%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ECORE_IMAGE_EXTRA_INSTALL%20%2B%3D%20%22xinput-calibrator%22%3C%2FSTRONG%3E%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%8B%E3%82%89%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3E%24%20bitbake%20fsl-image-test%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%83%93%E3%83%AB%E3%83%80%E3%83%BC%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81conf%2Flocal.conf%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3EEXTRA_IMAGE_FEATURES%20%2B%3D%20%22%E3%83%84%E3%83%BC%E3%83%ABSDK%22%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AB%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AB%E3%81%AF%E3%80%81%E9%96%8B%E7%99%BA%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E5%90%8C%E3%81%98%E3%82%82%E3%81%AE%E3%82%92%E4%BB%BB%E6%84%8F%E3%81%AEbb%E7%94%BB%E5%83%8F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%90%AB%E3%82%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%3E%0A%3CP%3EPoky%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%8B%E3%82%89%3A%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E'tools-sdk%22%3C%2FSTRONG%3E%20-%20gcc%E3%80%81make%E3%80%81pkgconfig%20%E3%81%AA%E3%81%A9%E3%81%AE%E9%96%8B%E7%99%BA%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%22dev-pkg%22%3C%2FSTRONG%3E%20-%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AB%20-dev%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E5%86%85%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E9%96%8B%E7%99%BA%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E4%BE%BF%E5%88%A9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%22tools-debug%22%3C%2FSTRONG%3E%20-%20gdb%20%E3%82%84%20strace%20%E3%81%AA%E3%81%A9%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%0A%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C%E8%8B%A6%E6%89%8B%E3%81%AA%E6%96%B9%E3%82%84%E3%80%81%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%8C%E3%81%8A%E5%A5%BD%E3%81%BF%E3%81%AE%E6%96%B9%E3%81%AF%E3%80%81HOB%E3%82%92%E3%81%94%E8%A6%A7%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%AF%E3%81%84%E3%81%8B%E3%81%8C%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%9B%E3%83%96%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fwww.yoctoproject.org%2Fdocumentation%2Fhob-manual%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.yoctoproject.org%2Fdocumentation%2Fhob-manual%3C%2FA%3E%3C%2FP%3E%3CP%3Ehob%E3%81%AE%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%AC%E3%82%A4%E3%83%89%E3%83%93%E3%83%87%E3%82%AA%E3%82%92%E8%A6%8B%E3%82%8B%20Hob%E3%81%AE%E7%B4%B9%E4%BB%8B%20-%20YouTube%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3EYocto%20Training%E3%81%B8%20-%20HOME%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-95045%22%20target%3D%22_blank%22%3E%E3%82%BF%E3%82%B9%E3%82%AF%20%235%20-%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3C%2FA%3E%E3%81%AB%E9%80%B2%E3%82%80%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1129220%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%236%20-%20%E7%94%BB%E5%83%8F%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%92%E7%94%BB%E5%83%8F%E3%81%AB%E8%BF%BD%E5%8A%A0%20%3CA%20href%3D%22http%3A%2F%2Fboundarydevices.com%2Fproducts%2F7-800x480-display%2F%22%20title%3D%22http%3A%2F%2Fboundarydevices.com%2Fproducts%2F7-800x480-display%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fboundarydevices.com%2Fproducts%2F7-800x480-display%2F%3C%2FA%3E%20%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E7%8F%BE%E5%9C%A8%E3%80%81%E7%A7%81%E3%81%AFfsl-image-gui-imx6sabreauto%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%94%BB%E9%9D%A2%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%BF%E3%83%83%E3%83%81%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CIMG%20id%3D%22smileysad%22%20class%3D%22emoticon%20emoticon-smileysad%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-sad.png%22%20alt%3D%22Smiley%20Sad%22%20title%3D%22Smiley%20Sad%22%20%2F%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81%E8%A8%80%E5%8F%8A%E3%81%95%E3%82%8C%E3%81%9F%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AF%E3%80%81Ubuntu%2012.04%E3%81%AE%E7%A7%81%E3%81%AEintel%20centrino%20duo%E3%81%A78%E6%99%82%E9%96%93%E3%81%A7%E3%82%BC%E3%83%AD%E3%81%8B%E3%82%89%E5%AE%8C%E5%85%A8%E3%81%AB%E6%A7%8B%E7%AF%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BD%95%E3%82%82%E3%83%91%E3%83%83%E3%83%81%E3%82%92%E9%81%A9%E7%94%A8%E3%81%9B%E3%81%9A%E3%81%AB%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3C%2FP%3E%3CP%3EBye%20bye%20LTIB...%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%236%20-%20%E7%94%BB%E5%83%8F%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129222%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Efsl-image-test.bb%20%E3%81%A7%E3%83%8F%E3%83%83%E3%82%AD%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%82%88%E3%82%8A%E3%82%82%E3%80%81%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E6%96%B9%E3%81%8C%E8%89%AF%E3%81%84%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Emeta-mylayer%2Frecipes-mylayer%2Fimages%2Fmylayer-image-test.bb%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2090px%3B%22%3E%E3%83%AC%E3%82%B7%E3%83%94-fsl%2Fimages%2Ffsl-image-test.bb%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2090px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2090px%3B%22%3EIMAGE_INSTALL%20%2B%3D%20%22%20%5C%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2090px%3B%22%3Exinput-calibrator%20%5C%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2090px%3B%22%3E%22%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2090px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2090px%3B%22%3E%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%20IMAGE_BASENAME%20%3D%20%22mylayer-image-test%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1129221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E3%82%BF%E3%82%B9%E3%82%AF%236%20-%20%E7%94%BB%E5%83%8F%E3%82%92%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1129221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AE%E9%81%8E%E7%A8%8B%E3%81%A7%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E5%86%85%E3%81%AB%E3%82%B9%E3%83%88%E3%83%AA%E3%83%83%E3%83%97%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E4%BE%BF%E5%88%A9%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81conf%2Flocal.conf%20%E3%81%A7%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EINHIBIT_PACKAGE_STRIP%20%3D%20%221%22%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎07-01-2013 06:10 AM
更新者:
